Papalala Posted August 14, 2018 Report Share Posted August 14, 2018 I have an 06 banshee with t9 pipes k&n filter and stock engine I have 280 mains and I think 25 pilot I run at 500 ft elevation and 100 degrees currently and my banshee bogs out at mid throttle what size should I put? thanks Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 14, 2018 Report Share Posted August 14, 2018 What carbs. Full exhaust or just silencers? Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 14, 2018 Report Share Posted August 14, 2018 Air box or pods? Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalala Posted August 14, 2018 Author Report Share Posted August 14, 2018 full exhaust stock carbs with airbox but lead is removedSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 15, 2018 Report Share Posted August 15, 2018 Air leaks? Pressureize the motor. What's your compression?Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalala Posted August 15, 2018 Author Report Share Posted August 15, 2018 Air leaks? Pressureize the motor. What's your compression?Sent from my SM-N920V using TapatalkThere are no air leaks but I dont know the compression because sadly i dont have a compression testerSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 15, 2018 Report Share Posted August 15, 2018 I'm running 265s with a 29 main at 500asl. Also dune ported and stroked. Seems like your mains are to rich. Did you plug chopSent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 15, 2018 Report Share Posted August 15, 2018 27.5sI'm running 265s with a 29 main at 500asl. Also dune ported and stroked. Seems like your mains are to rich. Did you plug chopSent from my SM-N920V using TapatalkSent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 15, 2018 Report Share Posted August 15, 2018 Pilot. Not mainSent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 15, 2018 Report Share Posted August 15, 2018 I'd start by plug chopping. If to rich. Go down. Did you do any work to cause this problem? Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalala Posted August 15, 2018 Author Report Share Posted August 15, 2018 I'm running 265s with a 29 main at 500asl. Also dune ported and stroked. Seems like your mains are to rich. Did you plug chopSent from my SM-N920V using TapatalkIm planning to do a plug chop tomorrow i will post the pics here Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalala Posted August 15, 2018 Author Report Share Posted August 15, 2018 I'd start by plug chopping. If to rich. Go down. Did you do any work to cause this problem? Sent from my SM-N920V using TapatalkWell I was bone stock about 1 year ago and it was perfectly fine with no bog then I bought a used pro circuit exhaust that had a wierd noise when you move its right pipe up and down but i thought its nothing then i put it on with 280 mains and it bogged like hell so after about 6months i bought brand new t9 pipes from the box to replace it and thought why not put the newer 280s as well. It helped alot but it still bogs a little.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalala Posted August 15, 2018 Author Report Share Posted August 15, 2018 I'm running 265s with a 29 main at 500asl. Also dune ported and stroked. Seems like your mains are to rich. Did you plug chopSent from my SM-N920V using Tapatalkalso would you recommend me to go 27.5 pilot or should i stay at 25?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
christoph.tamz Posted August 15, 2018 Report Share Posted August 15, 2018 Does it idle okay and up to half throttle?Sent from my SM-N920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Papalala Posted August 15, 2018 Author Report Share Posted August 15, 2018 Does it idle okay and up to half throttle?Sent from my SM-N920V using TapatalkIdles perfectly starts first kick every time then goes smoothly until half throttle.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
