Buckeye513 Posted August 13, 2018 Report Share Posted August 13, 2018 So during my last XC race my bike caught on fire at my wiring harness from spilt fuel. I replaced the harness and the coil that were damaged but now it won’t fire up. I have spark and fuel but is it possible the new coil I got is backwards and causing the spark to happen 180* out of time? Any helpful advice is welcome. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 13, 2018 Report Share Posted August 13, 2018 No. Both fire each time. Quote Link to comment Share on other sites More sharing options...
Buckeye513 Posted August 13, 2018 Author Report Share Posted August 13, 2018 No. Both fire each time. Could they be firing at the wrong time? Like on the scavenging stroke instead of compression stroke?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 13, 2018 Report Share Posted August 13, 2018 2 hours ago, Buckeye513 said: Could they be firing at the wrong time? Like on the scavenging stroke instead of compression stroke? Sent from my iPhone using Tapatalk Sure, if your timing key is gone or fucked up. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted August 14, 2018 Report Share Posted August 14, 2018 You probably damaged the stator or CDI box when the wires shorted out after the insulation burned off. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 18, 2018 Report Share Posted August 18, 2018 You said you have spark correct. So fuel n compression are your next two things. Put new plugs in it kick it and see if the plugs are getting wet Quote Link to comment Share on other sites More sharing options...
