B-shop164 Posted July 31, 2018 Report Share Posted July 31, 2018 Hello, i have a +4mm stroker and cool head 19 cc machined for 4mm stroker ! Whats gasket size i need for the cilinder ? .020? ( stock cilinder) Quote Link to comment Share on other sites More sharing options...
gusto Posted July 31, 2018 Report Share Posted July 31, 2018 Probably but I would if you can find out who built it and ask them. if your unsure call FAST and he can sort you out Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted August 1, 2018 Report Share Posted August 1, 2018 What is your squish clearance between the piston and the dome? You could adjust your base gasket to get the clearance you want. Most of them are between .020 and .030, but it ultimately depends on who did the porting and cut the domes. Start with your squish and see where you are at, that will give you a general idea of if you need a thicker or thinner gasket. Quote Link to comment Share on other sites More sharing options...
