guns4children Posted July 29, 2018 Author Report Share Posted July 29, 2018 19 hours ago, n2otoofast4u said: On 7/27/2018 at 3:49 PM, guns4children said: RRL told me the stator looks like it's not testing out. Guess I can order one of those and see if it helps. LMFAO...... YOU ARE LISTENING TO THAT VORTEX PRODUCING FRENCH CANADIAN???? COME ON CHIEF..... YOU KNOW BETTER THAN THAT! I figure there isnt a part he hasn't broken so he should know when something is screwed up! Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted July 30, 2018 Report Share Posted July 30, 2018 On 7/28/2018 at 1:15 AM, n2otoofast4u said: On 7/27/2018 at 3:49 PM, guns4children said: RRL told me the stator looks like it's not testing out. Guess I can order one of those and see if it helps. LMFAO...... YOU ARE LISTENING TO THAT VORTEX PRODUCING FRENCH CANADIAN???? COME ON CHIEF..... YOU KNOW BETTER THAN THAT! Hey.... im just going by what im seeing... If the tester is set up properly the readings he posted show that the stator is pooched... no 2 ways around it... so I don't get why no one is taking any attention to that.... seems like its a no brainer there unless the settings on tester arn't correctm, the stator should test 13.5 to 20ish if I remember right.... also the fact that his coil ohmed out properly within spec (the test he did without plug caps) figure he had the right setting... Quote Link to comment Share on other sites More sharing options...
guns4children Posted July 30, 2018 Author Report Share Posted July 30, 2018 2 hours ago, ride.race.live said: Hey.... im just going by what im seeing... If the tester is set up properly the readings he posted show that the stator is pooched... no 2 ways around it... so I don't get why no one is taking any attention to that.... seems like its a no brainer there unless the settings on tester arn't correctm, the stator should test 13.5 to 20ish if I remember right.... also the fact that his coil ohmed out properly within spec (the test he did without plug caps) figure he had the right setting... Well I have a new on on the way so we shall see. I'm putting my new vf3 petals on first. If that dont fix it I'm adding the new (expensive af) stator on. If that dont help I'm going to cry. I'll ship it to Jersey and let john part it. Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 3, 2018 Author Report Share Posted August 3, 2018 On 7/30/2018 at 10:33 AM, ride.race.live said: Hey.... im just going by what im seeing... If the tester is set up properly the readings he posted show that the stator is pooched... no 2 ways around it... so I don't get why no one is taking any attention to that.... seems like its a no brainer there unless the settings on tester arn't correctm, the stator should test 13.5 to 20ish if I remember right.... also the fact that his coil ohmed out properly within spec (the test he did without plug caps) figure he had the right setting... Well I have a new on on the way so we shall see. I'm putting my new vf3 petals on first. If that dont fix it I'm adding the new (expensive af) stator on. If that dont help I'm going to cry. I'll ship it to Jersey and let john part it. Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 3, 2018 Author Report Share Posted August 3, 2018 It was the reeds or the new filters. Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted August 7, 2018 Report Share Posted August 7, 2018 awesome no expensive fix.... still would figure out why you couldn't ohm the stator properly though in my opinion lol Quote Link to comment Share on other sites More sharing options...
ginger Posted August 7, 2018 Report Share Posted August 7, 2018 i was going to say i had a air filter issue that caused something similar. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted August 7, 2018 Report Share Posted August 7, 2018 6 hours ago, ride.race.live said: awesome no expensive fix.... still would figure out why you couldn't ohm the stator properly though in my opinion lol Because if you dont pay300$, the unit you have is cheepo and doesnt read correctly. Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted August 7, 2018 Report Share Posted August 7, 2018 Just now, ClaudeMachining said: Because if you dont pay300$, the unit you have is cheepo and doesnt read correctly. I got to Canadian tire testers at home and both read the same and have read within the proper specs when I tested electrical crap. also when guns ohmed tested his coil (without boots) it ohmed numbers within spec... Low battery on them will cause them to read funny but yea. Quote Link to comment Share on other sites More sharing options...
Keno Posted August 10, 2018 Report Share Posted August 10, 2018 On 8/7/2018 at 7:15 AM, ride.race.live said: awesome no expensive fix.... still would figure out why you couldn't ohm the stator properly though in my opinion lol probably didn't have the tester on the correct range for the values being looked for. This is why I prefer auto ranging meters. Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted August 10, 2018 Report Share Posted August 10, 2018 On 7/27/2018 at 3:23 PM, sleeper06 said: Are you sure your black lead is in the rite place? They are not. Quote Link to comment Share on other sites More sharing options...
Keno Posted August 11, 2018 Report Share Posted August 11, 2018 lol, Just saw that. I agree with Juan and sleeper. Black lead needs to be COM port Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 11, 2018 Author Report Share Posted August 11, 2018 On 7/30/2018 at 10:33 AM, ride.race.live said: Hey.... im just going by what im seeing... If the tester is set up properly the readings he posted show that the stator is pooched... no 2 ways around it... so I don't get why no one is taking any attention to that.... seems like its a no brainer there unless the settings on tester arn't correctm, the stator should test 13.5 to 20ish if I remember right.... also the fact that his coil ohmed out properly within spec (the test he did without plug caps) figure he had the right setting... Well I have a new on on the way so we shall see. I'm putting my new vf3 petals on first. If that dont fix it I'm adding the new (expensive af) stator on. If that dont help I'm going to cry. I'll ship it to Jersey and let john part it. Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 11, 2018 Author Report Share Posted August 11, 2018 Guess I should learn how to use my tester! Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted August 13, 2018 Report Share Posted August 13, 2018 On 8/11/2018 at 6:12 PM, guns4children said: Guess I should learn how to use my tester! LOL... that would help.... Quote Link to comment Share on other sites More sharing options...
