BigRed350x Posted July 15, 2018 Report Share Posted July 15, 2018 (edited) Getting everything cleaned and ready for reassembly on my buddy Mike's stock stroke engine. Shift star mod, shift pro roller bearing, pancake bearing, billet water impeller, new idler gear, adjustable timing plate, cleanup port on the cylinders, port matched cases, and all new seals and gaskets. K&N pod filters, TORS delete, FMF pipes. Edited July 15, 2018 by BigRed350x 1 Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted July 16, 2018 Report Share Posted July 16, 2018 Looks clean! Admire a well organized work bench too Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
registered user Posted July 16, 2018 Report Share Posted July 16, 2018 maybe your friend isnt interested but ive found oem cr500 bearing and washers to be much better than the cheezy bearing those pancake setups are supplied with Quote Link to comment Share on other sites More sharing options...
gusto Posted July 16, 2018 Report Share Posted July 16, 2018 Following! Glad your back on here and hope you do a nice detailed build for us Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 17, 2018 Report Share Posted July 17, 2018 8 hours ago, registered user said: maybe your friend isnt interested but ive found oem cr500 bearing and washers to be much better than the cheezy bearing those pancake setups are supplied with I've found some very cool replacements from RX350 transmissions as well. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted July 18, 2018 Author Report Share Posted July 18, 2018 Replacements for the pancake bearing? Shoot me some part numbers so I can check this stuff out! Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 19, 2018 Report Share Posted July 19, 2018 12 hours ago, BigRed350x said: Replacements for the pancake bearing? Shoot me some part numbers so I can check this stuff out! I'll call my buddy up at the core warehouse I was working in. Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted July 19, 2018 Report Share Posted July 19, 2018 Not sure who made that pancake bearing but I have been using the mattoon ones for years with no issues. Never seen one fail(when installed and adjusted properly). Just wondering what the point of sourcing a different one? Have you guys had failures? If so, explain.. Quote Link to comment Share on other sites More sharing options...
registered user Posted July 19, 2018 Report Share Posted July 19, 2018 the problem is the bearing and washer. not the main pancake piece that the rod pushes. im sure several companies are making the pancake setup but the one i bought looked like the bearing was made by little chinese kid with hammer and chisel. here u go bigred . washer 90608-072-000 bearing 91001-147-003 Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted July 19, 2018 Author Report Share Posted July 19, 2018 Nice, thanks man! Looks very similar. I'd be interested to see some hardness tests on the rollers and cages for comparison. I will have to pick up a couple and do a visual inspection... Quote Link to comment Share on other sites More sharing options...
registered user Posted July 19, 2018 Report Share Posted July 19, 2018 the honda bearing is a high qaulity ntn. bearing on the pancake setup i bought was cheezy garbage. the cage wasnt even symetrically round. i did have comparison photos. ill see if theyre still kicking around Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted July 24, 2018 Report Share Posted July 24, 2018 On 7/19/2018 at 3:35 PM, BigRed350x said: Nice, thanks man! Looks very similar. I'd be interested to see some hardness tests on the rollers and cages for comparison. I will have to pick up a couple and do a visual inspection... Post the results please. Rollers 54 rockwell C scale cage in the low 30’s Quote Link to comment Share on other sites More sharing options...
