Mrtaterman Posted July 6, 2018 Report Share Posted July 6, 2018 I have about an 80 est. Hp banshee, +4" swinger, 250lb rider. Currently I have 9 paddle bead to bead buff haulers. 68 ro (if I Remember right) smut only. They don't feel like they are hooking great on the hill. Running at 4 psi in the super soft stuff. Should I try less psi or more Paddles? Sent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted July 6, 2018 Report Share Posted July 6, 2018 (edited) 35 minutes ago, Mrtaterman said: I have about an 80 est. Hp banshee, +4" swinger, 250lb rider. Currently I have 9 paddle bead to bead buff haulers. 68 ro (if I Remember right) smut only. They don't feel like they are hooking great on the hill. Running at 4 psi in the super soft stuff. Should I try less psi or more Paddles? Sent from my SM-G930V using Tapatalk Get Paddle brats. I run those 9 paddle 3.5 psi and they hook hard in everything. I tried running 6 psi and it had noticeably more spin. You could try running 3 psi and see if it helps, im no pro on sand setup I just know what I have works good Edited July 6, 2018 by Ayesully810 1 Quote Link to comment Share on other sites More sharing options...
kawa110 Posted July 7, 2018 Report Share Posted July 7, 2018 Blackandyellowbanshee has some paddle brats in the for sale section. Or at least he did have some.... Quote Link to comment Share on other sites More sharing options...
Mrtaterman Posted July 7, 2018 Author Report Share Posted July 7, 2018 Get Paddle brats. I run those 9 paddle 3.5 psi and they hook hard in everything. I tried running 6 psi and it had noticeably more spin. You could try running 3 psi and see if it helps, im no pro on sand setup I just know what I have works goodWhat size are you running sullySent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
pp13bnos Posted July 7, 2018 Report Share Posted July 7, 2018 Try putting a little more gear to it. Quote Link to comment Share on other sites More sharing options...
Mrtaterman Posted July 7, 2018 Author Report Share Posted July 7, 2018 Try putting a little more gear to it.I was running slp with 15/41 gearing. I changed pipes to shearer and have not rode it yet. I'll try messing with psi with these new shearersSent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
