converting 421 cub to vp race fuel
i have a 421 cub setup for pump that i want to run 110 octane (vp c12 i believe its called)
here is my setup-
-full drag port, small bore shearers, 35mm pwk's, vforce4's, 3 degrees advanced, 8 inch pods, 140psi compression 22cc domes, squish= 0.055, at sea level. 160 mains 48 pilots runs good on 93 oct.
what size dome and compression should i be looking for??
Edited by mike0chek
The last cub I put together was 21cc and barely burned C12 completely. We ordered another set of domes from Dave @ Noss and went to 20cc. Nice sweet spot IMO. Enough compression to light the fuel right, and not so much that it hurts  RPM and over rev.
  • 4 weeks later...
