Hey fellas I have a question. I have stock carbs and stock air filter set up on the Ban. It seems like no matter what I’m always finding dirt/sand in the carbs.
What would I have to do to put pod filters and removed the whole stock air filter setup?
Also what size pods or kind should I get.
Dirt in carbs?34b47c29c5b454a2da8d7e3ac9406a36.heic
Yup just like that
Get a pro flow with uni and an outerwear pre filter. That happened on mine because my outerwear wasn’t all the way on and I filled my box with mud water as seen here
Definitely go pro flow adaptor and foam UNI in the stock box of you ride set stuff.  But UNI does sell clamp on filters to get rid of the box if you ride dry stuff.
