moneybags Posted June 4, 2018 Report Share Posted June 4, 2018 Im having a problem with by banshee melting the fuel line on the left carb. I can't seem to reroute the line any other way with out kinking the line or melting the fuel line. I have a 421 cheeta power valve motor in a lonestar frame with Inframe shear pipes and 35 pwk carbs. Ive herd you can get get pwk carbs with the fuel delivery port on ether side. Anybody know where I can get a new carb with the fuel port on the right side. Thanks Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 4, 2018 Report Share Posted June 4, 2018 A little heat shrink tube has always been my go to on several different types of pipes. Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted June 4, 2018 Report Share Posted June 4, 2018 https://www.keihin-na.com/aftermarket/pwk/ shows fuel inlet on right side of carb..... back (filter) looking front (intake) PWM has the fuel inlet on the other side, unfortunately it only comes in 38mm Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted June 4, 2018 Report Share Posted June 4, 2018 I just went to advanced auto and got the heat resistant line. it dont melt at all. ill send you a pic tomorrow morning of it Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted June 4, 2018 Report Share Posted June 4, 2018 10 minutes ago, Toybreaker said: https://www.keihin-na.com/aftermarket/pwk/ shows fuel inlet on right side of carb..... back (filter) looking front (intake) PWM has the fuel inlet on the other side, unfortunately it only comes in 38mm I have never seen a PWK with the inlet on the right, only the left. If you look at the pdf on the link above, it shows it on the left https://www.keihin-na.com/assets/1/7/pwk_parts.pdf But OP, have you tried using spacers to push the pipe away from the frame? Can you get pictures of the fuel line touching the pipe too? Quote Link to comment Share on other sites More sharing options...
ginger Posted June 4, 2018 Report Share Posted June 4, 2018 you want your fuel line as far away anyway, being you are losing power by heating fuel up, and risk fire in reality. I would see if the pipe can get pushed out some, or there has to be a way to route it. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 4, 2018 Report Share Posted June 4, 2018 Have you tried zip tying the fuel lines together? Do you run a dual Pingel or OEM tee? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 4, 2018 Report Share Posted June 4, 2018 Quote Link to comment Share on other sites More sharing options...
moneybags Posted June 5, 2018 Author Report Share Posted June 5, 2018 Yes, I'm running a duel pingle. I will see about getting a picture up tomorrow. I looked into spacing the pipe out. But don't think that would be a option. Spacing the front pipe out, only moved the middle of the pipe out maybe 1/2 inch. Do they make reed spacers for the cheeta? Thanks Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted June 5, 2018 Report Share Posted June 5, 2018 semi related question, but does the fuel heating at all really play any part in performance? ive never heard that before Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 5, 2018 Report Share Posted June 5, 2018 Definitely wanna see a pic, can you spin the Pringle to help in any way. Cascade used to have nice heat wrap Quote Link to comment Share on other sites More sharing options...
Keno Posted June 5, 2018 Report Share Posted June 5, 2018 I'm sure the fuel density changes. But it's probably a moot point. The biggest problem is when the fuel vaporizes is the fuel line! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 5, 2018 Report Share Posted June 5, 2018 Zip tie. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted June 5, 2018 Report Share Posted June 5, 2018 30 minutes ago, sleeper06 said: Definitely wanna see a pic, can you spin the Pringle to help in any way. Cascade used to have nice heat wrap he might be able to, but once ya pop the fun dont stop Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted June 5, 2018 Report Share Posted June 5, 2018 51 minutes ago, Ayesully810 said: semi related question, but does the fuel heating at all really play any part in performance? ive never heard that before Hot fuel builds less power then cold fuel. Wo yea it will hinder performance but you would never notice by the seat of the pants. Imo Quote Link to comment Share on other sites More sharing options...
