Jeovani101 Posted June 2, 2018 Report Share Posted June 2, 2018 Hi i have a 03 banshee with pod filters and Toomey t3 pipes other than that its bone stock. I run at sea level with temperature at 80-90 degrees. I need help on what I should run . Quote Link to comment Share on other sites More sharing options...
Jeovani101 Posted June 2, 2018 Author Report Share Posted June 2, 2018 im Currently running at 290 main, pilot 27.5 , toomey clip in the 3 grove from top Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 2, 2018 Report Share Posted June 2, 2018 What’s the issue, it’s safe to do a plug chip where it’s at. If it’s an issue that just started happening it’s not the jetting 1 Quote Link to comment Share on other sites More sharing options...
Jeovani101 Posted June 2, 2018 Author Report Share Posted June 2, 2018 it has a bog off idle should I go up or down on the pilot jet I'm currently running 27.5 Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 2, 2018 Report Share Posted June 2, 2018 Adjust the needle clip position before messing with pilot. Pu the clip all the way towards the taper side, if it gets worse move the clip all the way to blunt end. Do this first and report back. If it almost goes away we might be able to take care of it with the air screws 1 Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted June 4, 2018 Report Share Posted June 4, 2018 Needle adjustment should take care of the bog... Quote Link to comment Share on other sites More sharing options...
