booxzzy Posted May 29, 2018 Report Share Posted May 29, 2018 Just wondering what type of crankshaft bearings do you guys run?I'm in the middle of bottom and top end rebuild so the crankshaft needs to be done to but I'm not sure should I stick with genuine bearings or should I switch to Spherical Roller bearings... Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 30, 2018 Report Share Posted May 30, 2018 I use 8ball koyo across the board 1 Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted May 30, 2018 Report Share Posted May 30, 2018 If you have straight cut gears you need to run a tz bearing on the primary side imo.. if your running stock helix primary's the 8 ball bearing will work just fine Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 30, 2018 Report Share Posted May 30, 2018 I’ve been having better luck with 8 ball koyo over tz even with straight cuts. 100s of asphalt passes with almost no runout. Every time someone brings me an engine for a winter go over I check all crank parameters. The tz shows more wear in almost every case. I have even tried the 10 ball maxload and I’m back at the 8 ball. They just flat out last 1 Quote Link to comment Share on other sites More sharing options...
booxzzy Posted May 30, 2018 Author Report Share Posted May 30, 2018 I’ve been having better luck with 8 ball koyo over tz even with straight cuts. 100s of asphalt passes with almost no runout. Every time someone brings me an engine for a winter go over I check all crank parameters. The tz shows more wear in almost every case. I have even tried the 10 ball maxload and I’m back at the 8 ball. They just flat out lastMakes sense, can you give me the link where can I get it from?I was thinking of getting skf as I can get it from work trough supplier but if koyo is better, I rather go that way. Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
booxzzy Posted May 30, 2018 Author Report Share Posted May 30, 2018 BTW genuine Yamaha is 7 ball right? Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 30, 2018 Report Share Posted May 30, 2018 Yes factory is 7 ball Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 30, 2018 Report Share Posted May 30, 2018 The owners name is Dave (973)857-6464. Pick his brain on bearings this is what he does. Tell him Carl from Long Island said to give a shout. He’s super quick on shipping depending on where your at it’s usually 1-2 days. I found him through dragging street bikes. He’s built multiple sets of hybrid ceramic bearings for me and he supplies a couple factory race teams. Make sure you let him know 8 ball koyo for banshee crank and you need him to supply orings. He also does full engine ceramic kits for a Shee if you are looking to squeeze every little bit of power out of it and have the coin to do so. Any questions pm me and I’ll give you my cell Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 30, 2018 Report Share Posted May 30, 2018 Nothing wrong with skf I’m just comfortable with koyo, every one has there own opinions. I’ve rebuilt a ton of cranks so my opinion is based off the many failures I’ve seen or soon to be failures Quote Link to comment Share on other sites More sharing options...
kawa110 Posted May 30, 2018 Report Share Posted May 30, 2018 Glad I havnt assembles yet.....Looks like the tz bearings will stay on the shelf now...Sleeper knowledge priceless. Carl your one cool dude! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 1, 2018 Report Share Posted June 1, 2018 Don’t get me wrong the tz is a nice bearing. I’ve put them in plenty of builds back in the day with zero issues. What you have to remember is somewhere along the lines people were looking for upgrades on bearings. Shops are gonna sell what customer wants. People call builders 100 times a day asking for 10 ball maxloads or tz style bearings. Just because they sell it doesn’t mean it’s right Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted June 2, 2018 Report Share Posted June 2, 2018 On June 1, 2018 at 7:59 AM, sleeper06 said: Don’t get me wrong the tz is a nice bearing. I’ve put them in plenty of builds back in the day with zero issues. What you have to remember is somewhere along the lines people were looking for upgrades on bearings. Shops are gonna sell what customer wants. People call builders 100 times a day asking for 10 ball maxloads or tz style bearings. Just because they sell it doesn’t mean it’s right In theory more balls spreads he weight out better. However, you then end up with smaller balls and higher static load. There was a few really cool article way back on it from Timkin and SKF. I'll see if I can find it. Quote Link to comment Share on other sites More sharing options...
