I had the same problem with my t-5's. I tried everything i finaly called up toomey and the ended up sending me a set of new pipes. So thats what i would do if i were you they are very helpful.
If all else fails you MIGHT try loosening the motor mounts and see if you can shift the motor over a little bit...seems like Toomey mentions that on their webpage somewhere, something about Banshee motors not being perfectly aligned from the factory...
