Right exhaust not smoking like left
Well fellas I got her to where shee will start after 4 or 5 kicks with choke on,  the right exhaust isn' smoking like the left is and my right carb is leaking gas outta the over flow on the bottom of the bowl, is there a reason my right isn' smoking the same as the left , thank you for ur help
If the right is smoking more it’s crank seals but could be car issue
Adjust your floats to stop the leak,make sure the carbs are clean. Make sure your choke tube is intact.   Make sure the carbs have the same settings. How does it run?       If the right one smokes more it doesn’t mean it’s a crank seal,it could,but I find most of the time something else is out of whack.          Tuning isn’t going to help you very much until you fix your float/leaking issue
Edited by Burt Reynolds
