That can’t be good
oh. yeah well if its sucking trans fluid into the pipe its most likely from the right side seal easy fix. like zilla take clutch cover off and pressure test the motor you should find the leak that looks like trans fluid
I have two crank seals like 20 hrs on them only ill give them to you
I ordered some already but I appreciate that Bro.
When you consider that the youngest it be is 10 yrs old, shit breaks, wears out, rubber deteiorates. Besides doing leak down before AND after, replace BOTH sides. Don't buy cheap seals.
Any specific ones you’d recommend?
  • 1 month later...
