DirtyBP Posted May 22, 2018 Report Share Posted May 22, 2018 First time banshee owner, started to wish I never was. Can anyone point me in the direction to fix this?? All this poured out of that pipe. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted May 22, 2018 Report Share Posted May 22, 2018 What is premix ratio and oil? What is jetting, running good? Is it loosing trans oil? Quote Link to comment Share on other sites More sharing options...
DirtyBP Posted May 22, 2018 Author Report Share Posted May 22, 2018 What is premix ratio and oil? What is jetting, running good? Is it loosing trans oil?Was running good when I bought it. Fuel mix 32:1, I don’t know the jetting. And yes trans oil is low nowSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted May 22, 2018 Report Share Posted May 22, 2018 Might need a crank seal if trans fluid is going down. Quote Link to comment Share on other sites More sharing options...
DirtyBP Posted May 22, 2018 Author Report Share Posted May 22, 2018 Might need a crank seal if trans fluid is going down.Ffs. Far from what I’d like to hear. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted May 22, 2018 Report Share Posted May 22, 2018 Simple work really, should be able to get it on in a less than a day. Quote Link to comment Share on other sites More sharing options...
DirtyBP Posted May 22, 2018 Author Report Share Posted May 22, 2018 Simple work really, should be able to get it on in a less than a day.Anything else it could be or you’re pretty certain that’s it?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted May 22, 2018 Report Share Posted May 22, 2018 Going off the picture and your answers, I am leaning that way. The oil looks a little red tinted like trans fluids. Premix would be blacker. Also said you are loosing trans fluid, it has to be going somewhere. A quick way to check if crank seal is to leak down test engine and see. Quote Link to comment Share on other sites More sharing options...
DirtyBP Posted May 22, 2018 Author Report Share Posted May 22, 2018 Going off the picture and your answers, I am leaning that way. The oil looks a little red tinted like trans fluids. Premix would be blacker. Also said you are loosing trans fluid, it has to be going somewhere. A quick way to check if crank seal is to leak down test engine and see.Appreciate the quick reply, brotha. Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted May 22, 2018 Report Share Posted May 22, 2018 where are you located at. your original comment in the post made me LOL hang in there, learning these machines is a fun process dont let little hickups take the fun out of it its all learning Quote Link to comment Share on other sites More sharing options...
DirtyBP Posted May 22, 2018 Author Report Share Posted May 22, 2018 where are you located at. your original comment in the post made me LOL hang in there, learning these machines is a fun process dont let little hickups take the fun out of it its all learning I love learning, I’ve rebuild tons of trikes (dirty200 on 3ww) just frustrating. Thought I was buying a summer toy, not a summer project hAha. I’m in Maryland, 21701Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted May 22, 2018 Report Share Posted May 22, 2018 (edited) oh. yeah well if its sucking trans fluid into the pipe its most likely from the right side seal easy fix. like zilla take clutch cover off and pressure test the motor you should find the leak that looks like trans fluid I have two crank seals like 20 hrs on them only ill give them to you Edited May 22, 2018 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
Ride2fast Posted May 22, 2018 Report Share Posted May 22, 2018 Crank sealsSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Ride2fast Posted May 22, 2018 Report Share Posted May 22, 2018 Is it smoking really bad out the right exhaust Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ride2fast Posted May 22, 2018 Report Share Posted May 22, 2018 Is it smoking really bad out the right exhaust Sent from my iPhone using TapatalkAnd don’t get discouraged when I first got mine the crank seals were bad too and I knew nothing about four wheelers while rebuilding them watch some YouTube and I rebuilt that thing in less than a day it’s easy super easy and I had absolutely no small motor rebuild knowledge but I’m a good mechanic Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
