Dialing in
Looking for advice on where to start with my new build. 421 cub, drag port, .5 3 squish, 135 lb each side, 19 CC domes, thousand foot elevation.
6in K&N pods with outerwears, Lectron 38/40 HVs, Trinity stage 4 intakes, VF4 reeds.
R2 pipes.
Should I run 93 octane? Or add a booster?
Where should I start with timing?
135? sounds low for that setup. you know the port timings? feel like 19cc should put you a little higher than that.
thats pump gas range
you doing the compression test right with a quality tester?
Edited by Ayesully810
race fuel is 165 170 range.
throttle wide open and kick until the needle stops.  I have a decent tester, you dont need a craftsman but something good and make sure the tester adapter that screws in is the SAME length as the spark plug or you will get a different reading
