coleman Posted May 13, 2018 Report Share Posted May 13, 2018 Noob here Few days ago bike wasn’t starting, I checked the plugs and they looked very worn, so I put a new set in and it started first kick. I rode the bike 2-3 more times in between that and now it won’t start. These are the plugs I just put in Any ideas? Bike has toomey t5s, tors removed Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rippin'n'Runnin Posted May 13, 2018 Report Share Posted May 13, 2018 What's your jetting Quote Link to comment Share on other sites More sharing options...
coleman Posted May 13, 2018 Author Report Share Posted May 13, 2018 What's your jettingNot sure, bought it last spring and it ran fine until now. Anyway to see? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
coleman Posted May 13, 2018 Author Report Share Posted May 13, 2018 I got it running using starter fluid, do the plugs look okay?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted May 14, 2018 Report Share Posted May 14, 2018 I got it running using starter fluid, do the plugs look okay?Sent from my iPhone using TapatalkI thought that using starting fluid in a 2 stroke was not good to do since lack of lubrication to bearings? Definitely check jetting, it may not be that but it’s good to know what’s in there. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 14, 2018 Report Share Posted May 14, 2018 try cleaning the air filter 1 Quote Link to comment Share on other sites More sharing options...
Rippin'n'Runnin Posted May 14, 2018 Report Share Posted May 14, 2018 Remove carbs and take the bowls off to check jets. Videos on YouTube if you need them. Clean carbs and air filter real good. Tell us what you have. Also let us know what other mods you have Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 14, 2018 Report Share Posted May 14, 2018 If you've never taken a 2s apart, you have no idea how much residual oil is in the bottom of the case. It's starting fluid, not fuel. With evaporation rate you're lucky to get a couple of strokes out of a snort. Quote Link to comment Share on other sites More sharing options...
coleman Posted May 14, 2018 Author Report Share Posted May 14, 2018 17 hours ago, Banshee802 said: I thought that using starting fluid in a 2 stroke was not good to do since lack of lubrication to bearings? Definitely check jetting, it may not be that but it’s good to know what’s in there. Sent from my iPhone using Tapatalk Starter fluid i used has lubricant i'll try to take the carbs apart. Pray for me and hope i dont screw something up Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted May 14, 2018 Report Share Posted May 14, 2018 44 minutes ago, coleman said: Starter fluid i used has lubricant i'll try to take the carbs apart. Pray for me and hope i dont screw something up you wont screw them up taking them apart only putting them back together dear Lord help coleman amen Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 15, 2018 Report Share Posted May 15, 2018 Do one at a time. Bowls and slides are different, and will go in wrong carb. Quote Link to comment Share on other sites More sharing options...
coleman Posted May 15, 2018 Author Report Share Posted May 15, 2018 Now I’m confused. Before I took it apart went to go start it it started first kick. Today it’s 75 out and the day it didn’t start it was about 65. Do I still take it apart? Also I recently acquired some Elka stage 3 suspension. What would you scale the difficulty to put them on?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
coleman Posted May 16, 2018 Author Report Share Posted May 16, 2018 Got the shocks onIgnore the shitty graphicsSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted May 16, 2018 Report Share Posted May 16, 2018 I would lean tword a plugged pilot jet for the not starting(if you have already checked to make sure it has good spark) dont use eather to start it, use flammable carb clean(carb clean has oils in it, not much but some, and you wont hurt it with carb clean) but you shouldn't need anything if it's right. When you started it on starting fluid did it idle? Front shocks is as easy as pulling 4 bolts Quote Link to comment Share on other sites More sharing options...
coleman Posted May 16, 2018 Author Report Share Posted May 16, 2018 Just now, JUSTWANNARACE said: I would lean tword a plugged pilot jet for the not starting(if you have already checked to make sure it has good spark) dont use eather to start it, use flammable carb clean(carb clean has oils in it, not much but some, and you wont hurt it with carb clean) but you shouldn't need anything if it's right. When you started it on starting fluid did it idle? Front shocks is as easy as pulling 4 bolts The bike started perfectly with the fluid. idled just fine after that Quote Link to comment Share on other sites More sharing options...
