Banshee802 Posted May 11, 2018 Report Share Posted May 11, 2018 Ok so I’m in a bit of a dilemma. I have 2 sets of cases one is good without chain wack and the other is not. The one that is without chain damage has rusty studs, a small pry mark (not sure if that’s major), and the bushings that mount it seem a little worn. The one without chainwack looks polished with clean studs and nice looking mounts. Which set of cases would you guys use?? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted May 11, 2018 Report Share Posted May 11, 2018 wire brush the rusted studs, if the threads look good use the non whacked case. Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted May 11, 2018 Author Report Share Posted May 11, 2018 wire brush the rusted studs, if the threads look good use the non whacked case.All the threads are good for both cases. That little pry mark won’t affect anything will it? Is there anyway I can swap the clutch arm needle bearings?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted May 11, 2018 Report Share Posted May 11, 2018 If there is raised metal that will interfere with the cases sitting flush then you need to make the seating surface flat. If it does not get into the sealing area then it is fine. Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted May 11, 2018 Author Report Share Posted May 11, 2018 If there is raised metal that will interfere with the cases sitting flush then you need to make the seating surface flat. If it does not get into the sealing area then it is fine.Seen in picture 2. I’ll have to take them apart and checkSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted May 11, 2018 Report Share Posted May 11, 2018 It doesn't look like anything will be raised when you split them, but I can not tell from the photo. Quote Link to comment Share on other sites More sharing options...
Keno Posted May 12, 2018 Report Share Posted May 12, 2018 You'll destroy the clutch arm needle bearing getting it out, so just buy a new one they are around $11. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 21, 2018 Report Share Posted June 21, 2018 Blind bearing puller, I take them out all the time and there still useable Quote Link to comment Share on other sites More sharing options...
