KC_Hubbs Posted April 15, 2018 Report Share Posted April 15, 2018 I bought my first Banshee today. Ive always wanted one, and today I was finally able to get it. I bought it from a local guy, and he had a little trouble getting it started. First he changed plugs in it, he said the plugs would foul if you left the gas turned on for long periods of time. Next, the guy had to push start it to get it started. After that, it ran great and he even used the kick start a few times to show me it running. Then i loaded in my truck and brought it home. A few hours later I went to start it and I cant get it to start using the kick start. I havent tried push starting it yet. Can anyone offer any suggestions on what I can do for it ? Only mods I can tell that have been done is an aftermarket exhaust. Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted April 15, 2018 Report Share Posted April 15, 2018 What's the compression at?Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
KC_Hubbs Posted April 15, 2018 Author Report Share Posted April 15, 2018 I was actually searching for a compression testing tool just now. Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted April 15, 2018 Report Share Posted April 15, 2018 I was actually searching for a compression testing tool just now.You can rent one at AutoZone if you don't have one. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
KC_Hubbs Posted April 15, 2018 Author Report Share Posted April 15, 2018 Any thoughts on this ? https://www.amazon.com/INNOVA-3612-Compression-Tester-Piece/dp/B000EVU89I/ref=sr_1_3?ie=UTF8&qid=1523835903&sr=8-3&keywords=compression+test&dpID=41JS6DGRRNL&preST=_SY300_QL70_&dpSrc=srch Quote Link to comment Share on other sites More sharing options...
BlackandYellowBanshee Posted April 15, 2018 Report Share Posted April 15, 2018 (edited) Clean up the carbs really well and then check what jetting is in it. Pilot jet may be off. Also check the pick up gap on the flywheel and make sure the flywheel and pickup coil are nice and clean. Edited April 15, 2018 by BlackandYellowBanshee Quote Link to comment Share on other sites More sharing options...
KC_Hubbs Posted April 16, 2018 Author Report Share Posted April 16, 2018 Ill check all of that stuff out, right after work tomorrow. I would love to get this thing running right. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 16, 2018 Report Share Posted April 16, 2018 I’d check compression first. If it has 120+, it should start pretty easily. Below that and you’ll be kicking it more. Below 100 is rebuild time. Then, if compression checks out, pull the carbs and clean them completely, jets, passages and all. Also post what jets are in it so we can determine if it’s close or not. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 16, 2018 Report Share Posted April 16, 2018 Then if that doesn't work, check the reeds. Quote Link to comment Share on other sites More sharing options...
KC_Hubbs Posted April 17, 2018 Author Report Share Posted April 17, 2018 I just came in from cleaning the carb. Seems like both pilot jets were stopped up. Pilot jets had 2.5 stamped on them. The main jet had what looked like 200 or 002. It was hard to see. Now im having a little trouble getting the caps back on the carbs. I still have the tors system. Any pointers ? I'll be doing a compression test tomorrow. Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted April 17, 2018 Report Share Posted April 17, 2018 I just came in from cleaning the carb. Seems like both pilot jets were stopped up. Pilot jets had 2.5 stamped on them. The main jet had what looked like 200 or 002. It was hard to see. Now im having a little trouble getting the caps back on the carbs. I still have the tors system. Any pointers ? I'll be doing a compression test tomorrow. The cap with the little dimple goes on the left carb with the choke. You kind of have to put it on at an angle. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted April 17, 2018 Report Share Posted April 17, 2018 I just came in from cleaning the carb. Seems like both pilot jets were stopped up. Pilot jets had 2.5 stamped on them. The main jet had what looked like 200 or 002. It was hard to see. Now im having a little trouble getting the caps back on the carbs. I still have the tors system. Any pointers ? I'll be doing a compression test tomorrow. You should also delete your TORS when you get a chance. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 17, 2018 Report Share Posted April 17, 2018 26 minutes ago, KC_Hubbs said: I just came in from cleaning the carb. Seems like both pilot jets were stopped up. Pilot jets had 2.5 stamped on them. The main jet had what looked like 200 or 002. It was hard to see. Now im having a little trouble getting the caps back on the carbs. I still have the tors system. Any pointers ? I'll be doing a compression test tomorrow. Make sure the threads on both sides are clean, clean, clean and start them easy and square. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 17, 2018 Report Share Posted April 17, 2018 20 minutes ago, Banshee2105 said: The cap with the little dimple goes on the left carb with the choke. You kind of have to put it on at an angle. Sent from my Pixel XL using Tapatalk Cap? Dimple? Angle? What? Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted April 17, 2018 Report Share Posted April 17, 2018 Cap? Dimple? Angle? What? I'm not sure how to interpret this comment. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
