westside19899 Posted April 10, 2018 Report Share Posted April 10, 2018 both of my carb are leakin/ i rebuild da carb and it still leakin.help plese Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted April 10, 2018 Report Share Posted April 10, 2018 check your float level. research what setting they should be at (no idea what carbs you have) and make sure their set. Also make sure the needle valve is clean and free of debris... a q tip with a LITTLE bit of toothpaste will polish the tube and ensure its clean Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted April 10, 2018 Report Share Posted April 10, 2018 http://farmandsandtoys.com/ocart2/categories/carbs-intakes?limit=25&page=3 https://www.partzilla.com/catalog/yamaha/atv/2002/banshee-yfz350p/carburetor part #8 is the culprit. If you did not change it, you will not fix the leak Quote Link to comment Share on other sites More sharing options...
westside19899 Posted April 10, 2018 Author Report Share Posted April 10, 2018 i have stock carb Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted April 11, 2018 Report Share Posted April 11, 2018 16 hours ago, westside19899 said: i have stock carb See the post above yours. If you did not replace part #8 it will not stop leaking Quote Link to comment Share on other sites More sharing options...
