Jeovani101 Posted February 25, 2018 Report Posted February 25, 2018 I have a 03 banshee with t3s on it air box mod, tors delete and im 335 elevation and usually ride in 60-90 degree weather. still has stock jets and i need to know what size jets i should use. THank you Quote
Toybreaker Posted February 26, 2018 Report Posted February 26, 2018 start with 300 mains 27.5 pilot, go buy the toomey needles and install all that with the needle in the middle. should be safe and fat at that, but still run ok. do plug chops and post pics of the results (use the search function if you do not know how to do a plug chop) Buy 25-30 pilots and 270-330 mains so you can tune, and 24 plugs ( you will use a bunch tuning and doing the plug chops) Quote
