EaCastillo00 Posted January 27, 2018 Report Posted January 27, 2018 Hello guys i just wanted to ask you if my jetting sound close or kinda rich, cause ive been hearing mixed opinions so i just wanted your Point of view, i know the best way to know is a spark plug chop but i just wanted to see whay you think just by seeing the numbers; ok so here it goes Stock Cilinder, no port job, elevation around 600 ft above sea level, vforce reeds, k&n pro flow kit, T5 full exhaust, no snorkel, vented stock air box with lid, standar pistons, mull engineering mega flow impeller, oversized aluminum radiator using 30 pilots, 290 mains, neddle clip on middle position, air screw 2 and a half turns out, should i throw smaller pilots? Quote
