trickedcarbine Posted July 24, 2018 Report Share Posted July 24, 2018 8 hours ago, RagunCajun said: Have you tried it on 39's? Mine didnt work. Did you do any grinding on the stop? Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted July 24, 2018 Report Share Posted July 24, 2018 9 hours ago, trickedcarbine said: Did you do any grinding on the stop? I kept removing material in the throttle body housing until the arm inside had enough throw to fully open the carbs. There's one guy on the hq group on FB that says his opened 39's. Refused to take a few minutes to pop the top for the thumb throttle housing cover open to show me what he did to make it work along with refusing to remove the air filters to show me the carbs fully open. Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted July 24, 2018 Report Share Posted July 24, 2018 Claude I had the chariot extended thumb lever. I never noticed any tension difference when I went from my 35's to 39's. But I will say it took some time to get a hang of the extended thumb lever. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted July 24, 2018 Report Share Posted July 24, 2018 I think cam put easier springs in my 39's. It isnt bad at all. The only bad part is my short stuby fingers. I have to release my full grip to push the lever in from idle. Ill be getting a chariot one of these days. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted July 24, 2018 Author Report Share Posted July 24, 2018 I'll get a chariot kit. Quote Link to comment Share on other sites More sharing options...
gusto Posted July 24, 2018 Report Share Posted July 24, 2018 Talk to Jeff at FaSt he recommended Moose 1 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted July 26, 2018 Author Report Share Posted July 26, 2018 So here is a little dull video of the bike running, you can ear the thing rip a little bit. Thumb was killing me, so i go light. When i came back from this ride, i decided to lube the cable, re-route it (there was a little kink) and cut 2 coils from the springs. It worked!!! Now i have about the same feel, even maybe a little bit easier than my last to seasons with 35mm!!! Will do a ride tomorrow and see. https://youtu.be/KGUY558eK3k 1 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted July 26, 2018 Report Share Posted July 26, 2018 My what small hand u haveSent from my XT1080 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted July 26, 2018 Report Share Posted July 26, 2018 Looks and sounds good Claude. Sent from my LG-H831 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted July 26, 2018 Report Share Posted July 26, 2018 When I put my 7mil together this year I picked up some carbs from ben martins and they had the oem keihin springs in it, I just switched to the easy springs from fast and its crazy how much easier it is on the thumb. I had them in my 421 i had and forgot how much the difference is between the two. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 29, 2018 Report Share Posted July 29, 2018 On July 24, 2018 at 7:49 AM, RagunCajun said: I kept removing material in the throttle body housing until the arm inside had enough throw to fully open the carbs. There's one guy on the hq group on FB that says his opened 39's. Refused to take a few minutes to pop the top for the thumb throttle housing cover open to show me what he did to make it work along with refusing to remove the air filters to show me the carbs fully open. All I had to do was use the longer Keihin adjusters from FAST and grind the nub in the throttle housing. Quote Link to comment Share on other sites More sharing options...
mike0chek Posted July 29, 2018 Report Share Posted July 29, 2018 On 7/26/2018 at 11:46 AM, Ayesully810 said: When I put my 7mil together this year I picked up some carbs from ben martins and they had the oem keihin springs in it, I just switched to the easy springs from fast and its crazy how much easier it is on the thumb. I had them in my 421 i had and forgot how much the difference is between the two. yup the easy springs from fast are the answer for big carbs, extended throttle even better lol Quote Link to comment Share on other sites More sharing options...
gusto Posted July 29, 2018 Report Share Posted July 29, 2018 Sweet ride Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted August 6, 2018 Author Report Share Posted August 6, 2018 For the first time I did some hard pulls. It look like I'm pretty spot on jetting wise. 175 mains, 55 pilots (will go 58) , DGH middle clip Envoyé de mon SM-G935W8 en utilisant Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted August 6, 2018 Report Share Posted August 6, 2018 looks sweet now post some videos of some hard pulls with that thing not just putting around!! Quote Link to comment Share on other sites More sharing options...
