Banshee Noob Posted January 14, 2018 Report Posted January 14, 2018 Okay, so I am very new to working on and fixing issues and I’m wondering if you guys couple help me out. So I’ve got a 2004 banshee with a fresh top and bottom end with 160 psi compression in both cylinders, carbs are syncd in and I have toomey t5 pipes and a 2 to 1 air filter from toomey i can not figure out why I’m getting more smoke out of the left pipe thanks Quote
trickedcarbine Posted January 15, 2018 Report Posted January 15, 2018 Is it slow to return back to idle when you when you blip the throttle? Quote
Banshee Noob Posted January 15, 2018 Author Report Posted January 15, 2018 9 hours ago, trickedcarbine said: Is it slow to return back to idle when you when you blip the throttle? No it’s not Quote
trickedcarbine Posted January 15, 2018 Report Posted January 15, 2018 Ok, good news is that usually rules out air leak. Quote
Banshee Noob Posted January 15, 2018 Author Report Posted January 15, 2018 1 hour ago, trickedcarbine said: Ok, good news is that usually rules out air leak. That’s great to know. I was kind of thinking a jet could be clogged. Is that a possibility? Quote
Gazlay43 Posted January 15, 2018 Report Posted January 15, 2018 That’s great to know. I was kind of thinking a jet could be clogged. Is that a possibility?Very possible Sent from my iPhone using Tapatalk Quote
bluebanshee32 Posted January 31, 2018 Report Posted January 31, 2018 Clogged pilot will do this for sure. Pull your choke out and see if the other pipe wakes up. Quote
Banshee Noob Posted February 1, 2018 Author Report Posted February 1, 2018 1 hour ago, bluebanshee32 said: Clogged pilot will do this for sure. Pull your choke out and see if the other pipe wakes up. Problem solved. I had a clogged puppet and was running lean thanks for all the help Quote
