New setup way off.
brock42
  • Replies 73
  • Created
  • Last Reply
Top Posters In This Topic
How hot is it where u are at? u should just keep the pods on unless ur riding in wet crap all the time.  imo i think a stock pilot will do with just pods and pipes as long as its not really cold where your at
Edited by Ayesully810
44 minutes ago, brock42 said:
No change still best when needle is almost closed.
What does this mean? What are u adjusting?
If it swings that much I would run a 27.5 pilot and try it with 2 turns out on your air / fuel screw and turn it in if it needs more fuel. is your choke tube hooked up?
I was told it was completely stock.  I had to replace a base gasket and noticed it looked as if it may have had some kind of porting work done. And when the choke is pulled it does rev better. But when I install 30 pilots it acts the same way. It's almost as if it needs a bigger pilot but from what I've got it should t need anymore.
Edited by brock42
