ZillaFreak Posted August 17, 2018 Report Share Posted August 17, 2018 1 hour ago, .Spencer. said: So here is the info he sent me: Hey Joel, So what I usually supply & build for Banshee’s is a pair of full adjustable piggyback shocks that I make the correct eye to eye and stroke length. I then re-valve them to your weight and the quads specs (the +2 arms). They have new shaft bushing’s, o-rings, wiper and main seals. I remove, replace and stack the compression and rebound valve shims using the right diameter shims stacked in the correct order for your specs. Fresh synthetic oil, nitrogen charge to the correct psi. Once the shocks are built I resurface and paint the shock bodies special edition black using a high heat ceramic enamel paint. The progressive coil springs are sandblasted and powder coated to match the quad or desired color. Cost of the shocks,build and re-valve would be $420 for the pair. Shipping is $25 so $445 shipped. Also if your budget allows I would suggest having your rear shock rebuilt to your specs and to match the new valve to front shocks. Depending on your weight and the length of the rear swingarm cost would be between $150 and $190 for me to rebuild, re-valve and put the correct spring rate for your specs with everything I do to the front shocks including paint and powder coat. If you have any questions at all or just want to pick my brain feel free to give me a call. Thanks, Sent from my SM-G892U using Tapatalk Um isn't a very important part of setting up a shock for your weight the spring rate? A heavier person would need a heavier springs, same with a heavier quad and a longer arm. He seems like he really cares about putting lipstick on the shocks and not about making them work 100%. Does he dyno the shocks? Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted August 17, 2018 Report Share Posted August 17, 2018 https://www.bansheehq.com/forums/index.php?/topic/154225-2010-yfz-450-front-suspension-swap/&do=findComment&comment=1380563 This is the reason I would never use Jogaca shocks. Anyone this guy named dropped is not worth being associated with. I wish more of the post were in that thread but ya he is bad. Quote Link to comment Share on other sites More sharing options...
.Spencer. Posted August 19, 2018 Report Share Posted August 19, 2018 Point taken. I will keep an eye out for some fox floats. Until then, I'm just gonna get a cheap set of used stockers to replace my blown out shocks. Thanks for all the help.Sent from my SM-G892U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Adam187 Posted July 5, 2021 Report Share Posted July 5, 2021 On 1/12/2018 at 2:28 PM, Gazlay43 said: Has anybody been brave enough to try these? They look a little better than the original ones that originally started popping up on eBay. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F371802517728 These are the original ones I'm talking about. They look a lot weaker https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F391926925243 Sent from my iPhone using Tapatalk I have the predator Banshee shocks and they work very well for the price they work as well as shocks double the price Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 6, 2021 Report Share Posted July 6, 2021 I rode a bike with a set of his shocks. Not impressed at all. Quote Link to comment Share on other sites More sharing options...
caleb90 Posted July 6, 2021 Report Share Posted July 6, 2021 On 7/5/2021 at 2:11 PM, Adam187 said: I have the predator Banshee shocks and they work very well for the price they work as well as shocks double the price ok Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 7, 2021 Report Share Posted July 7, 2021 6 hours ago, caleb90 said: ok And what he means by "OK"... is bullfuckingshit. Quote Link to comment Share on other sites More sharing options...
