thapres! Posted January 7, 2018 Report Share Posted January 7, 2018 only one of my pipes is smokng need to know what t do to fix it Quote Link to comment Share on other sites More sharing options...
kawa110 Posted January 7, 2018 Report Share Posted January 7, 2018 Sell the bike Quote Link to comment Share on other sites More sharing options...
BlackandYellowBanshee Posted January 8, 2018 Report Share Posted January 8, 2018 What side is leaking? Check your idle screw. Check your sync at idle with a carb sync tool. Clean carbs. Perform a leak down test to see if you have a bad crank seal or stator side seal. I think a leaking key way will cause right side smoke. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 13, 2018 Report Share Posted January 13, 2018 Need more details. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 14, 2018 Report Share Posted January 14, 2018 Are both cylinders firing? Which side smokes more? Quote Link to comment Share on other sites More sharing options...
