4mill short rod bottom end
1 hour ago, Duke 2 Stroke said:
I have a 4mill short rod bottom end I just put together and I have a friend of mine that have a set of oem cylinders full drag ported that he took off his 4mill long rod setup. My question is can I use that same top end with my my short rod bottom end
You should be able to put them on and run a normal banshee piston instead of the typical Weisco 795 piston.  I'd suggest getting a few different base gaskets to mock it up and see where it sits the best.
  • Like 1
