How do I fix this?
So I'm pretty sure this crank that I got for this motor is a stroker crank and that's the issue here. I'm trying to do an all stock setup.
I need to know how to fix this ASAP. I have a trip coming up and I *really* don't want to tear this engine back down.
Is there anything I can do? Of course if I have to I will tear then engine down and replace the crank.
This crank is welded. If it comes down to it, anyone game to trade for a stock crank?
Thanks guys!25318b2b22b49c8b6dd26c56d92f5eee.jpg5ad3730757cec27c8015070e5d34ccf4.jpg
Sent from my Pixel XL using Tapatalk
If I was to guess it is a long rod crank and you need 795 long rod pistons. To stick out that far with the correct pistons it would have to be a 10mm stroke or bigger. Cause a 7mm stroke with 115mm rods and 795 pistons the ring will not come out of the cyl. A 10mm stroke with a 795 piston the rings will come our of the cyl..
1 hour ago, JUSTWANNARACE said:
If it's a stock stroke long rod with stock style pistons it's going to stick out 5mm.. if it's a 4mm long rod with stock style pistons it's going to stick out 7mm ect..
So I just measured and at TDC the piston is sticking out 5mm. What is the fix for this?
Edited by Banshee2105
Typo
