gforce15 Posted December 23, 2017 Report Share Posted December 23, 2017 421 wampus refuses to start. bought it from a guy was not running apparently he had just built it. got it home clean the carbs put new plugs in and it started an ran good. pulled it apart powdered the frame put it together and it still started and ran good. left it alone for a week was going to ride it and it would not start. I have checked all grounds tested stator, coil, and swapped cdi with a none good one no luck. did a leak down passed that. has 150 psi on both cylinders. carbs have been cleaned and floats adjusted. noticed there was a grey milky liquid at the bottom of crank turned bike upside down got that out. I kick it over it try's to start and occasionally will half ass run for a second and dies. when the plugs are in the motor and I kick it they do come out a little wet but not bad. ive tried 4 sets of plugs. also have checked pick up coil distance that's good any thoughts Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 23, 2017 Report Share Posted December 23, 2017 Starting fluid is your friend!Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
gforce15 Posted December 23, 2017 Author Report Share Posted December 23, 2017 tried that to no luck Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 23, 2017 Report Share Posted December 23, 2017 What was the grey milky shit in the crank case? Almost sounds like it's sucking in some trans fluid. Have you done a leak down on this thing? Have you pulled the clutch cover and inspected the clutch side crank seal? I wonder if when assembled they didn't put any 1211 on the keyway and it's sucking trans fluid in. Which side of the crank case had the fluid? How did you see it in there? Quote Link to comment Share on other sites More sharing options...
gforce15 Posted December 23, 2017 Author Report Share Posted December 23, 2017 did a leakdown passed that holds 7 psi for way longer than 7min. have not inspected any seal on clutch side. I saw it with a bore scope camera and then flipped it up side down to get it out. the fluid was in the crank valley under the rods. right where cases get trenched. after you kick it and it trys to start it will push air and smoke out of the carbs Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 23, 2017 Report Share Posted December 23, 2017 Hmm, that's strange. So it won't even start with starting fluid? I think I'd tear the whole thing down and inspect/rebuild. Something isn't right. Quote Link to comment Share on other sites More sharing options...
gforce15 Posted December 23, 2017 Author Report Share Posted December 23, 2017 that's what I was thinking of doing I wanted to see if you guys had any ideas that I have not tried before I went that route. I do appreciate the ideas Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 23, 2017 Report Share Posted December 23, 2017 The only other thing I can suggest is swapping electrical parts one more time. I have seen CDIs work intermittently. Coils usually work or they don't. I'm sure stators and flywheels can work off and on but I haven't experienced that. Otherwise, what about your wiring harness? Kill switch? What type? I had a Tusk kill switch go bad at the dunes this year. Even with the "key" in the kill switch, starting was intermittent. Quote Link to comment Share on other sites More sharing options...
gforce15 Posted December 23, 2017 Author Report Share Posted December 23, 2017 ill try that I have 2 other banshees to pull from. the wiring harness is stock with all tors and e brake crap unplugged. kill switch is the stock one Quote Link to comment Share on other sites More sharing options...
Keno Posted December 23, 2017 Report Share Posted December 23, 2017 after you kick it and it trys to start it will push air and smoke out of the carbs What do your reeds look like? Any petals missing? Quote Link to comment Share on other sites More sharing options...
gforce15 Posted December 24, 2017 Author Report Share Posted December 24, 2017 reeds look good you can see a very minor amount of light through them no missing petals none are cracked Quote Link to comment Share on other sites More sharing options...
