Jeovani Pacheco Posted December 21, 2017 Report Share Posted December 21, 2017 I have a 03 banshee I’m a noob to this I was wondering why my banshee won’t start it gives good spark and I checked compression it has 90 and I cleaned the carbs and it still doesn’t start Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 21, 2017 Report Share Posted December 21, 2017 I have a 03 banshee I’m a noob to this I was wondering why my banshee won’t start it gives good spark and I checked compression it has 90 and I cleaned the carbs and it still doesn’t startSo you checked it has spark, the carbs are clean so it's probably getting air. Last thing is fuel. If everything else is okay make sure fuel is getting delivered. Make sure a line isn't blocked or pinched shut. Make sure your gas valve isn't all gunked up, take it out and clean/inspect it. You can also pop the fuel line off a carb, turn the gas on and see if anything is coming out. You may want to clean your tank and lines if some nasty fuel was sitting in there. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 21, 2017 Report Share Posted December 21, 2017 Also 90 PSI is a bit low compression. Stock Banshees are usually around 120 PSI. Might be time for a top end. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jeovani Pacheco Posted December 21, 2017 Author Report Share Posted December 21, 2017 I am getting gas to both carbs is their anything else I could check Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 21, 2017 Report Share Posted December 21, 2017 I am getting gas to both carbs is their anything else I could checkIs it even even wanting to fire? Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rippin'n'Runnin Posted December 21, 2017 Report Share Posted December 21, 2017 (edited) If your compression is really 90psi , then that is a big part of your problem. Edited December 21, 2017 by Rippin'n'Runnin Quote Link to comment Share on other sites More sharing options...
Jeovani Pacheco Posted December 21, 2017 Author Report Share Posted December 21, 2017 I think it needs a new top end rebuild Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 21, 2017 Report Share Posted December 21, 2017 Also make sure you're using a compression tool designed for motorcycles. Kevin from South Texas Banshee sells some on eBay I think they're like $50. But the automotive ones are not accurate for motorcycles. The hose is usually too long. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted December 21, 2017 Report Share Posted December 21, 2017 The hose length shouldn't have any effect on compression tester if the valve is in the tip. Quote Link to comment Share on other sites More sharing options...
