Single Carb
badbonz
My friend got a single carb kit for his banshee. Trinity sells the whole kit with gaskets, the 35mm carb, the 2 into 1 intake setup, a steel braided throttle cable, and a clamp on k+n filter w/ outerwear for $490. Its not bad for what it does for your banshee. If I had the money, I would get it definitely. It cleans the motor compartment up a lot, and gives you a lot more space for working on it. Its also easier to tune one carb instead of two. They put a jet in it for you for a banshee with pipes and the clamp on obviously. The bike has way more low end now. It started the second kick after putting it on . Its definitely a good part to get. ;)
A holley dominator with custom manifold, no but really; What are your engine mods before you do anything that effects the performance of your shee such as the carb size? Since you didn't list anything can we assume stock? Piped? Ported?
