Banshee2105 Posted December 7, 2017 Report Share Posted December 7, 2017 Hey guys! So I was recommended to weld my flywheel puller on to my fucked flywheel to get it off. Well, it didn't work and I am a shitty welder. I also don't think the welder was getting hot enough (Harbor Freight ). Oh well, it was worth a try. So, does anyone know of a shop preferably in Orange County, California that can remove this flywheel? I would like to keep the stator intact and not mar the crank also. But I have a feeling this thing is going to need to be pressed off and if that doesn't work, cut off. And if it has to be cut, I can say goodbye to my stator. Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 7, 2017 Author Report Share Posted December 7, 2017 Hey guys! So I was recommended to weld my flywheel puller on to my fucked flywheel to get it off. Well, it didn't work and I am a shitty welder. I also don't think the welder was getting hot enough (Harbor Freight ). Oh well, it was worth a try. So, does anyone know of a shop preferably in Orange County, California that can remove this flywheel? I would like to keep the stator intact and not mar the crank also. But I have a feeling this thing is going to need to be pressed off and if that doesn't work, cut off. And if it has to be cut, I can say goodbye to my stator.PhotosSent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Brooklyn350 Posted December 7, 2017 Report Share Posted December 7, 2017 Look up a jaw gear puller. I've used them to pull Yfz450 flywheels without a hitch. I'm sure the bigger ones can be adjusted to fit over the banshee flywheel and it will not damage anything. Good cheap tool to have laying around anyway Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted December 7, 2017 Report Share Posted December 7, 2017 You can rent them at autoparts stores Quote Link to comment Share on other sites More sharing options...
IceracerX Posted December 7, 2017 Report Share Posted December 7, 2017 Tat flywheel looks to be bent badly from someone using a jaw type puller, and it seems it didn't work. You need some one with a better welder to weld the puller onto the flywheel. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted December 7, 2017 Report Share Posted December 7, 2017 Try turning that harbor freight welder up.....If the weld penetrates, it will work. Take it to any muffler shop—-they usually have a good old welder “guy” Quote Link to comment Share on other sites More sharing options...
spurdy Posted December 7, 2017 Report Share Posted December 7, 2017 I've had to cut a couple off before. You can do it without damaging the crank or the stator if you take your time. If the woodruf key has rocked in the keyway, you will never pull it off or press it off. I had one stuck once and had it in a 10 ton press and it wouldn't budge. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted December 7, 2017 Report Share Posted December 7, 2017 10 hours ago, Brooklyn350 said: Look up a jaw gear puller. I've used them to pull Yfz450 flywheels without a hitch. I'm sure the bigger ones can be adjusted to fit over the banshee flywheel and it will not damage anything. Good cheap tool to have laying around anyway you see the damage currently on the flywheel? ya, that happened from a jaw puller. never use a jaw puller to get a banshee flywheel off as it can cause the damage seen above. Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted December 7, 2017 Report Share Posted December 7, 2017 11 hours ago, Banshee2105 said: Photos Sent from my Pixel XL using Tapatalk The welded didn't get hot at all. Hold it on there a little longer and turn the amps up more. Get the juice flowing and get the welded to penetrate both the flywheel and puller good. Get it red hot. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 7, 2017 Report Share Posted December 7, 2017 If it's not some expensive billit crank, use a box end wrench to loosen the timing plate bolts. Split the cases and toss the crank and flywheel in the trash. Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 7, 2017 Author Report Share Posted December 7, 2017 I've had to cut a couple off before. You can do it without damaging the crank or the stator if you take your time. If the woodruf key has rocked in the keyway, you will never pull it off or press it off. I had one stuck once and had it in a 10 ton press and it wouldn't budge. Sent from my iPhone using Tapatalk What tool did you use to make these cuts?Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 7, 2017 Author Report Share Posted December 7, 2017 Try turning that harbor freight welder up.....If the weld penetrates, it will work. Take it to any muffler shop—-they usually have a good old welder “guy”I had the cheap one. It only had two settings Min and Max. I had it on Max and I feel like I had the wire speed at a good rate and it still did nothing but spitter spatter. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted December 7, 2017 Report Share Posted December 7, 2017 1 minute ago, Banshee2105 said: I had the cheap one. It only had two settings Min and Max. I had it on Max and I feel like I had the wire speed at a good rate and it still did nothing but spitter spatter. Sent from my Pixel XL using Tapatalk you have gas in it? last time i used the mig, it was very low on gas and ran out, it would pop and spatter and didn't give a good weld. Quote Link to comment Share on other sites More sharing options...
spurdy Posted December 7, 2017 Report Share Posted December 7, 2017 What tool did you use to make these cuts?Sent from my Pixel XL using Tapatalk4.5" grinder and a die grinder with a cut off wheel after I ground the river heads off with a grinding wheel. You just have to be careful not to cut into the taper of the crank. It's dirty and time consuming but it will save your crank and stator. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee2105 Posted December 7, 2017 Author Report Share Posted December 7, 2017 The welded didn't get hot at all. Hold it on there a little longer and turn the amps up more. Get the juice flowing and get the welded to penetrate both the flywheel and puller good. Get it red hot.I had that cheap ass welder on Max and that was still the result. I returned it and HF deemed it to be defective. I think I'm going to just cut it off as suggested by another user. I really appreciate your advice man. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
