Outter Crank Bearings
gunnin4elvis
Hey all, I'm getting ready to swap my crank with a max load and tz. I have the crank in the freezer and wondering what techniques have worked best for you. How do you heat the bearings to get them off the crank and how do you heat the new bearings to get them on. Was thinking torch for bearings on crank, and oven?? for the tz and max. All suggestions will be appreciated.
Heat the new bearings to 275-300
use welding gloves to put them on.
Make sure to put it on straight. If you cock the bearing you will fuck up the crank.
there is only a .0004”-.0007” press fit
heated properly you wont need a press to put them on.
Use heat on old bearings,use a tapered punch or seperater until you get it in press or puller on it.
Installing new ones , welding gloves and 10 thou on each side just the inner race, I use map gas . If you get that uncertain Pm me your cell number and I can send you a video of me doing it later. Keep in mind I have made tools to do crank work over the years
