06YFZ350 Posted November 16, 2017 Report Share Posted November 16, 2017 Wow This banshee is kicking my ass, my 06 is for sure a problem child. I think my carbs may be my issue. I have stock carbs on my banshee I paid a shop 1600 bucks to do the work on my bike and since i got it back the thing has not run like I expected it to. First it was super rich fouling plugs like crazy then i took it back and it ran good for a few mins then would brake up. I finally said fuck that shop cut my loses and started to work on it myself. I have stock carbs on the bike with a vitos tors delete kit. I resyncd the carbs using the window on the side of the carb and it ran ok but now it seems only one pipe is getting hot and its not smoking from the other pipe. I am thinking about pulling off the stock carbs and trying to get them setup/jetted correctly but another option would be to buy a whole new carb setup. I also am willing to go to a 2 into 1 carb setup since i feel like it would be very easy to get running good. I have a carb model yfz and it runs great and the carb seems to never give my problems i wish my banshee ran as well as my yfz as i have sunk alot of cash into this banshee and it still doesnt run right. Im looking for suggestions on what you guys can recommend i do. Im willing to take the stock carbs off and go through them and make sure they are all set to spec if that is what you guys think is a good starting point. Quote Link to comment Share on other sites More sharing options...
Canadianshee Posted November 16, 2017 Report Share Posted November 16, 2017 Will need more information on your current setup. What your current jetting at, any mods done to bike ECT. Your location (evelvation) ECT, ECT Leakdown test Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 16, 2017 Report Share Posted November 16, 2017 Pipe temp difference is likely to float level adjustment from my experience. Should be 21mm from base to top of float with no gasket. Keep the stockers u can get em to work just be patient. 1600 bucks to work on carbs ? Mamma miaEdit: as stated above. Mods needed aling with riding temps and elevationSent from my LGMS210 using Tapatalk Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 16, 2017 Author Report Share Posted November 16, 2017 1 minute ago, Ayesully810 said: Pipe temp difference is likely to float level adjustment from my experience. Should be 21mm from base to top of float with no gasket. Keep the stockers u can get em to work just be patient. 1600 bucks to work on carbs ? Mamma mia Sent from my LGMS210 using Tapatalk It was 1600 for labor to do the complete rebuild and i provided A complete parts package for the build "TURN KEY" is how it was supposed to be returned to me but that did not happen lol. I do not even know what jets are in it because he is the one who put them in. I can pull the carbs off and find this information out. As canadianshee said i have not done any leak down test or anything and i can also provide a complete lits of the parts on my bike and mods. I just need to type them all up and i will do that now. I am willing to buy a leak down test kit for banshee i am litterally willing to do what ever it takes to get my shee correct! Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 16, 2017 Author Report Share Posted November 16, 2017 (edited) NEW after market 64mm cylinders Wiseco 513M06400 pro lite piston kits Hotrods heavy duty crankshaft assembly Pro Design billet Cool Head with 19cc domes trail/Mx port nothing crazy Vitos Tors delete kit Vforce 3 reeds Toomey T6 pipes Pro design Billet intake on the oem air box with a K&N filter/Pre filter with no lid. Stock Carbs +4 degrees on timing plate 93 octane mixed 32:1 klotz super techniplate +++Jets currently are unknown but I will update this when pull off the carbs.+++ Elevation: Im in Florida at sea level temperature currently is around 70-80 degrees in the day here Edited November 16, 2017 by 06YFZ350 Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 16, 2017 Report Share Posted November 16, 2017 Whats ur compression? 19cc domes on a lower port timing cylinder might put you in race fuel compression numbers. Id work your way down from a 320 mainAnd a 30 pilot with ur needle clip on the 4th. Just my 2 cents. Depends on whats in there now though those r just numbers thst ive seen work on stock stroke/ported setupsSent from my LGMS210 using Tapatalk Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 17, 2017 Author Report Share Posted November 17, 2017 Ok just checked the jets in the right side carb the main jet says AB310 and the pilot says 25 Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 17, 2017 Report Share Posted November 17, 2017 Check both carbs lol and check ur conpression too with those 19 cc domes to make sure u dont need tonrun race fuel or get bigger domes to run pump fuel. I would think that pilot is on the lean side tooSent from my LGMS210 using Tapatalk Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 17, 2017 Author Report Share Posted November 17, 2017 Ok i will pull the other carb right now! Yea the kit i bought was supposed to come with 22cc domes but i know i checked them when i opened the package and it had 19cc engraved on it. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 17, 2017 Report Share Posted November 17, 2017 Ok i will pull the other carb right now! Yea the kit i bought was supposed to come with 22cc domes but i know i checked them when i opened the package and it had 19cc engraved on it. 22 or 23 ccs would put u arpund 140 psi. Over 160 esp 170 u wanna start looking at race fuelSent from my LGMS210 using Tapatalk Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 17, 2017 Author Report Share Posted November 17, 2017 Ok both carbs have 25 pilots and 310 mains the needles which i gave him a "toomey perfect jet kit" may be toomey needles and the clip is at the very bottom towards the sharp point i think 6 positions down. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 17, 2017 Report Share Posted November 17, 2017 Ok both carbs have 25 pilots and 310 mains the needles which i gave him a "toomey perfect jet kit" may be toomey needles and the clip is at the very bottom towards the sharp point i think 6 positions down.Bring the needle up to the 4thSent from my LGMS210 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 17, 2017 Author Report Share Posted November 17, 2017 1 minute ago, Ayesully810 said: Bring the needle up to the 4th Sent from my LGMS210 using Tapatalk is that the 4th slot up from the point? Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted November 17, 2017 Report Share Posted November 17, 2017 Also, test that compression. Yes toward middle. And adjust ur float. Where r your air screws at too? How many turn out from seated Sent from my LGMS210 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
06YFZ350 Posted November 17, 2017 Author Report Share Posted November 17, 2017 Im not sure i will check that next, Thank you sully for helping me I really do appreciate all the help and you replying to my posts. Quote Link to comment Share on other sites More sharing options...
