I ride mainly in Pennsylvania coal mountains so lots dust/mud/water It's an 01 with pro design foam filter with the airbox lid. Fmf gnarly pipes. Timing is at +2. Stock carbs measured 28mm. Aftermarket needles. Currently running 280 with 27.5 pilot. And it's like it can't rev out bogs
On 11/7/2017 at 4:12 PM, Ayesully810 said:
needle position? which needle? Toomey?
It's on 4th notch from the bottom. And I'm not sure of needle brand this how I've got it it's has 6 notchs
Put 260s in there, lean the needles all the way out and see if it revs . Once it does plug chop it. I've had 240s be perfect and also 260s depending on the bike. If you're climbing the hills you should chop and tune on the hill under load
