I just got. A banshee ✊✊👍👍🔥🔥😍
Meezy420
I just got my banshee i noticed that the tors system was already taken off but i dont think they bored the new hole in the stock carb the carba idle screws are hella loose i cleaned the carbs but it still bogs when i crank it i know i need new reeds it looks like there bent but i was wondering should i buy a new carb 30mm becuz i dont want to drill and tap stock ones ill be too nervous i mess them up i have vito performance with two into one k&n no jetting in carb everthing is stock in carb and there is v force reeds just old as shit and bent wondering what i do and One more thing i stay in new orleans i mean its getting kinda chilly now but other wise its hot and humid 80°-97° weather all year round and below sea level
A- Welcome to BHQ
B- Nothing wrong with stock carbs. If you even have idle screws and no TORS tops, that means someone has already drilled and tapped. Do
    you have a jam nut on the screw? That will hold it once the adjustments are made. Post a pic of the side of the carbs.
C- Use some punctuation, some of us are old and don't read or comprehend gud as it is.
  • Like 3
 Sorry about the text talk and the punctuations Im kind of on the young side.  I drove a long way to get my banshee thou florida to new orleans. Im about to take a pic but it wont let me upload big pictures ill be sending some.  It wont let me upload pics that are 51.5kb but my pic from my phone only come as low as in 64mb trying to send a pic thou.
I do have a jam nut on it but i dont trust that the guy i bought it from took the tors out the right way I.e. all the drilling and tapping included.  I took a tors out my buddys BANSHEE but he had the same problem but i remember that I didnt tap that screw for them.. Im kinda of scared to tap myself but if Itry and mess up I ll buy a new carb thats why I was wondering would it be ok if i use a 32/34 chariot carb. Seems to not be getting enough gas...
 sbsc9y.jpg  :RIGHT SIDE One pic here man its hard to shrink a damn pic I am young but im not a tech head shits confusing.. lol
Edited by Meezy420
Welcome to the forums. I live in Lafourche parish. Good luck finding a legal place to ride down here. There's the spillway but it sucks for wide open stuff. The mud bikes and side by sides tore everything up. I went last year and i didnt get out of 2nd gear.
Stock carbs are fine. Like he said, it should have a jam nut and those work fine. Getting bigger carbs wont solve you not knowing how to work on a bike nor jet a carburetor. It is a pita to learn.
  • Like 1
.,Gotcha will get out there and try to tune thats why I had to sign up for the forum i grew up bringing everything i own to the shop but i realized that i was paying an arm and leg for simple work i could have done at home... But
You are right there is no where to ride down here thats why you see alotta ppl on the streets riding lol i probably started that down here always was out for mardi gras tearing up the city
But i will try to tune my stock carbs im goin to check all the wiring and make sure that the tors is completely gone... But i did buy a rebuild kit along with a new choke becuz it was bent plus the tors delete kit with just the tap and drill along with new idle screws so hopefully it comes together nice if not i will be lost on what to get next becuz i've been reading about buying a new carb but i have hard evidence to go off now... hope it works out good....
plus i seen that my reeds were bent ordering new ones just wondering if that would be the problem too its not blocking anything its just not the way it supposed to be would that hurt any???????
Gotcha will do....My rebuild kit comes in today so I will keep everybody posted on the results but I will just get my idle right because I don't want those Reed causing any more problems👌🤘👍
He said you need to make sure it has no leaks. So make or a buy a leakdown tester and see if it has leaks. Otherwise, you may be chasing your tail until the engine fails. You can search youtube and these forums on how to make one. I think someone on ebay makes them if you dont want to piece one together.
  • Like 1
Damn will do i put the rebuild kit on new vitos idle screw and new choke it starts in about 2-3 kicks but i couldnt get it to idle and my pipe on right side was getting less smoke than the other idk if its just me but it seems like my idle screw has no comtrol.on the idle
MY SYPMTOMS: ARE THAT it starts but doesnt stay idle and when I throttle it it moves but its little or no power even when WOT but it doesnt bog unless i take my thumb off the throttle but it did bog on me the last time and wouldnt kick back up on my thinking bout buying a top end kit Just becuz i know ppl wear them down...
It is two carbs 2 idle screws in carb and two came with kit but spark plugs are filling fast i just changed them managed to get enough power to take off but it still lagged then it gave me a little power then i filled my spark plugs
MY LEFT SPARK PLUG FILED OUT BUT MY RIGHT LOOKS BRAND NEW I ROAD MY MANSHEE(LOL) JUST AROUND THE BLOCK AND THE LEFT PLUG FILED ON ME WHAT SHOULD THAT TELL ME
