obbb Posted October 10, 2017 Author Report Share Posted October 10, 2017 Alright.... so it could be over heating or developing an electrical issue once hot... or be something as basic as needing a carb clean from partially clogged jets. Thats not a 4 stroke "breaking on you" all the time.. its the same issue you cant fix or figure out. Any other bike can and will come up with issues sooner or later...I just cleaned the carbSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted October 10, 2017 Report Share Posted October 10, 2017 What 4 stroke do you current have? Quote Link to comment Share on other sites More sharing options...
obbb Posted October 10, 2017 Author Report Share Posted October 10, 2017 What 4 stroke do you current have?Wolverine 450. It’s to slow Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted October 10, 2017 Report Share Posted October 10, 2017 what bike do you have right now thats bogging out after 10 mins... did you change anything and then it started doing it... or did it just start doing it out of no where. Loosing coolant? Quote Link to comment Share on other sites More sharing options...
obbb Posted October 10, 2017 Author Report Share Posted October 10, 2017 what bike do you have right now thats bogging out after 10 mins... did you change anything and then it started doing it... or did it just start doing it out of no where. Loosing coolant? Yamaha wolverine 450Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted October 10, 2017 Report Share Posted October 10, 2017 I have a bike ill sell you, only catch is that there is no brakes, so you must ride in a very large area where you can allow gravity to slow you down. msg me if u wanna do business Quote Link to comment Share on other sites More sharing options...
salmon_slayer06 Posted October 10, 2017 Report Share Posted October 10, 2017 Try building a motor than buy the suspension parts swinger axles, stator, Hinson clutch.. like 3 grand for clutch alone, steering stem, blue label wheels razor tires, shearer in frame pipes, carbs, v4 reeds, fuel valve, etc than get a used frame online. You want new crank, new bearings in motor all around. Used engine case is fine. You can buy good used trans gears online. Get new forks, new shift shaft new star and idler bushing and clip. Boxes and boxes of goodies piled up to the ceiling. Do a 4 mill serval. Quote Link to comment Share on other sites More sharing options...
obbb Posted October 10, 2017 Author Report Share Posted October 10, 2017 Try building a motor than buy the suspension parts swinger axles, stator, Hinson clutch.. like 3 grand for clutch alone, steering stem, blue label wheels razor tires, shearer in frame pipes, carbs, v4 reeds, fuel valve, etc than get a used frame online. You want new crank, new bearings in motor all around. Used engine case is fine. You can buy good used trans gears online. Get new forks, new shift shaft new star and idler bushing and clip. Boxes and boxes of goodies piled up to the ceiling. Do a 4 mill serval. NoSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
coleman Posted October 11, 2017 Report Share Posted October 11, 2017 Some of these guys are crazyYou don’t need to spend 10k on a bike to have fun. I would much rather have a stock Banshee than a banshee with 10,000 put into it, I like going full throttle and not just tapping the gas. But that’s just my opinion, if you wanna go fast, which a stock banshee is still pretty quick, drop 10k on oneBanshees are fun because of the powerband and the low center of gravity compared to the raptor IMO but the yfz has a pretty wide base so it’s all up to your preferencesSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted October 11, 2017 Report Share Posted October 11, 2017 1 minute ago, coleman said: Some of these guys are crazy You don’t need to spend 10k on a bike to have fun. I would much rather have a stock Banshee than a banshee with 10,000 put into it, I like going full throttle and not just tapping the gas. But that’s just my opinion, if you wanna go fast, which a stock banshee is still pretty quick, drop 10k on one Banshees are fun because of the powerband and the low center of gravity compared to the raptor IMO but the yfz has a pretty wide base so it’s all up to your preferences Sent from my iPhone using Tapatalk usually someone that spends 10k on a bike is not putting it around just taping on the gas. except for claude. also that guy above you was trolling im pretty sure, if not his post was a wtf post Quote Link to comment Share on other sites More sharing options...
coleman Posted October 11, 2017 Report Share Posted October 11, 2017 usually someone that spends 10k on a bike is not putting it around just taping on the gas. except for claude. also that guy above you was trolling im pretty sure, if not his post was a wtf postYeah but I don’t think anyone should think they will have to drop 10,000 on their first banshee that’s for sureSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted October 12, 2017 Report Share Posted October 12, 2017 That's not usually how it works. Its this 1. buy banshee for 2 grand off craigslist 2. dump 8 grand into it after it gets boring 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 12, 2017 Report Share Posted October 12, 2017 I wasn't trolling when I said you could spend 10K. Stockish banshees with a few bolt ons are fun for sure. But in a couple years you'll be addicted to how fast these things can actually go. Before you know it, you'll be asking guys about how to do a mean 4 mil and buying all the right chassis parts to keep ridable. It adds up quick is all I meant. 1 Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted October 12, 2017 Report Share Posted October 12, 2017 16 minutes ago, trickedcarbine said: I wasn't trolling when I said you could spend 10K. Stockish banshees with a few bolt ons are fun for sure. But in a couple years you'll be addicted to how fast these things can actually go. Before you know it, you'll be asking guys about how to do a mean 4 mil and buying all the right chassis parts to keep ridable. It adds up quick is all I meant. not you, I meant the guy right above me, salmon man Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted October 12, 2017 Report Share Posted October 12, 2017 3 hours ago, coleman said: Some of these guys are crazy You don’t need to spend 10k on a bike to have fun. I would much rather have a stock Banshee than a banshee with 10,000 put into it, I like going full throttle and not just tapping the gas. But that’s just my opinion, if you wanna go fast, which a stock banshee is still pretty quick, drop 10k on one Banshees are fun because of the powerband and the low center of gravity compared to the raptor IMO but the yfz has a pretty wide base so it’s all up to your preferences Sent from my iPhone using Tapatalk A stock banshee is not quick. It also has terrible handling. It is way to narrow and is actually top heavy. Once you drop some cash into the suspension, making it wider, it is a lot better. Shit, 10k into a banshee is nothing really. Buying a quad for 2500-3500 (stock). Dropping 2500 (arms, axle, shocks, stem, damper) into suspension, then another 2k (porting, new top end, head, reeds, clutch, trans, and nee parts) into engine parts, it would be a good banshee. That is 8k and it is still a stock size engine with some work. 1 Quote Link to comment Share on other sites More sharing options...
