Shanar2139 Posted October 4, 2017 Report Share Posted October 4, 2017 I was riding my banshee I grabbed clutch to changed gears then I suddenly noticed it lost tension I looked at the engine and noticed the clutch shaft was sticking up out the engine I tried pushing it back down but it just isn't budging please help I'm starting to lose interest 😩 Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted October 4, 2017 Report Share Posted October 4, 2017 Tear engine apart. Quote Link to comment Share on other sites More sharing options...
blowit Posted October 12, 2017 Report Share Posted October 12, 2017 I assume you mean the clutch "arm". There is a retainer that bolts over that to keep it down. If that is not there, you need one!  If that did come up, you may not have success reinstalling without first removing the clutch cover and removing the clutch pressure plate, which will remove any tension on the pushrod. You will need to pull the pushrod and ball back towards the right side so the arm will go in.  If you persist in trying to jam the arm down, you may succeed in damaging the bore it rides in. Then you get to do a full teardown.   Also, IIRC, I think there may be a soft plug right by the front sprocket that gains access to that bore. You would have to drill/extract/replace that plug but if it is there, you can push the rod back there and reinstall, which would eliminate the need to remove the clutch cover.   Brandon Mull Engineering Quote Link to comment Share on other sites More sharing options...
