hells_yea Posted October 3, 2017 Report Share Posted October 3, 2017 I just completed my build. Did a Wiseco Stock Crank 9 (#WPC100), Wiseco Pistons (# 513M06475), Rebored, etc... Got it all together and both cylinders have a max of 60psi compression. They both match pretty much exactly. It will start and run but wont put any power to the wheels, something is wrong but I can't narrow it down.Took the Cylinders back to the machinist to confirm clearence and it's perfect at .002", Ring end gap is perfect. Both pistons have the proper #s on top. I did a squish test and it was inconclusive (wouldn't touch a piece of solder that was .040", I need to get thicker solder). I am not getting any blowby into the coolant system, I even copper coated the head gasket just to be extra sure. I'm pretty much at a loss for what is going on and need some fresh minds on it. Any suggestions are welcome. Quote Link to comment Share on other sites More sharing options...
hotrod9193 Posted October 3, 2017 Report Share Posted October 3, 2017 What head do you have on the bike? Sent from my SM-G930R4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hells_yea Posted October 3, 2017 Author Report Share Posted October 3, 2017 2 minutes ago, hotrod9193 said: What head do you have on the bike? Sent from my SM-G930R4 using Tapatalk Stock, Sorry Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted October 3, 2017 Report Share Posted October 3, 2017 15 minutes ago, hells_yea said: Stock, Sorry Arrow on piston pointing tword the exhaust? Are you kicking it till the needle on the tester stops moving? Have you verified your tester is good? And .002 piston to wall is pretty damn tight.. jmo Quote Link to comment Share on other sites More sharing options...
hells_yea Posted October 3, 2017 Author Report Share Posted October 3, 2017 (edited) 4 minutes ago, JUSTWANNARACE said: Arrow on piston pointing tword the exhaust? Are you kicking it till the needle on the tester stops moving? Have you verified your tester is good? And .002 piston to wall is pretty damn tight.. jmo Yes, first thing I checked Yes, even tested it coasting down a hill Yes, put air to the tester and it matches compressor output .002 is tight, but this machinist has done at least 100 bores for my fathers business and every bore he's done for me personally has been that tight. You get a little compression boost, but it makes it a real fucker to kick. It's never given me a reliability issue. Standard clearance is around .003. This banshee doesn't even feel right when you kick it, just feels like its worn out.... IDK Edited October 3, 2017 by hells_yea Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted October 3, 2017 Report Share Posted October 3, 2017 How thick are the base gaskets you used? Oem? Is it a bone stock headno machining)? Quote Link to comment Share on other sites More sharing options...
gusto Posted October 3, 2017 Report Share Posted October 3, 2017 Air leak somewhere? Quote Link to comment Share on other sites More sharing options...
hotrod9193 Posted October 3, 2017 Report Share Posted October 3, 2017 Should do a leak down test Sent from my SM-G930R4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hells_yea Posted October 4, 2017 Author Report Share Posted October 4, 2017 1 hour ago, JUSTWANNARACE said: How thick are the base gaskets you used? Oem? Is it a bone stock headno machining)? All Gaskets are OEM Head is 100% bone stock AFAIK Quote Link to comment Share on other sites More sharing options...
hells_yea Posted October 4, 2017 Author Report Share Posted October 4, 2017 1 hour ago, hotrod9193 said: Should do a leak down test Sent from my SM-G930R4 using Tapatalk Yeah, I'm thinking that's the next step... I really hate doing leak downs.... Quote Link to comment Share on other sites More sharing options...
hotrod9193 Posted October 4, 2017 Report Share Posted October 4, 2017 Yeah, I'm thinking that's the next step... I really hate doing leak downs....There a pain in the ass but necessary.Sent from my SM-G930R4 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
