521 banshee
Richard2112
Forged crank or billet if your rich. Contact KAN powersports and get him to make you a crank or TDRs 10 mil. CP super serval cylinders, 39 PWK carbs, UPP intakes, Matoon or Chariot clutch basket, Slingshot of finger style lockup, Chariot head, pro mod tranny, Shearer, Sniper or CPI exhaust.
cam at redline builds good servals
Just looking back through what's everyones opinion on these.
Sent from my LG-H910 using Tapatalk
Billet crank, billet cases, straight cut gears, billet clutch, lock up, billet clutch cover, billet transmission, don't use KAN as they suck, billet dm head, dm cylinders as super cub are just weak, 41pwk, vf2 reeds. this should make you fast enough.
Is there anything super cub that you would use
On 9/11/2017 at 4:22 PM, Richard2112 said:
Just to restate that a bit an mx track banshee.
That's a terrible idea. It's too much power.
On 9/11/2017 at 5:49 PM, Richard2112 said:
My budget is 5000 if I can stay around that I would like to
You will need triple that to achieve your goal unless you buy used junk.
On 9/11/2017 at 6:15 PM, SandSlingerOR said:
Just a heads up that 521 will be unrideable and just plain not fun for the track. Dunno if this is serous build or not, but you should just rebuild that motor and spend the rest on your suspension and what not.
This is spot on.
On 9/11/2017 at 6:37 PM, specialblend07 said:
It'll cost you $7k to build this new with exhaust.
This is also spot on. I have the invoices to prove it.
On 9/11/2017 at 6:38 PM, Richard2112 said:
Ok I hear what everyone is saying ill upgrade my suspension as well but I'm doing the 521 anyway I want someone to give me recommendations on parts
There's countless threads on suspension. Use the search function.
On 9/11/2017 at 6:39 PM, Richard2112 said:
This is a serious build I'm starting with the motor and going from there
That's how i did it.
On 9/11/2017 at 7:01 PM, Ayesully810 said:
There is no reason for any of us here to explain this when we have THIS. This thread right here has everything you will need to know about your  build.  God speed friend. Here is the link.
The bike isnt even finish. How about you listen to the guys who have spent a lot of time on a 110hp bike. So far, you are not taking their advice.
On 9/11/2017 at 8:48 PM, Ayesully810 said:
btw where is Codys 521 serval page? I cant find it.  That would be better.  I was jk on payment plans thread. Its mostly just people roasting him the whole time and by people I mean griff.
see below.
On 9/11/2017 at 9:42 PM, trickedcarbine said:
Core parts $1000
Misc. OEM parts $400
Crank $1500
Cylinders $1000
Misc. machine work $1000
Trans $300
Clutch and Lock up parts & cover $500
Now add pipes, carbs, electronics, reeds, and all the other supporting stuff. Double your budget if you plan on making the chassis safe enough to handle a 521 super fun on spray.
For a 521 full build..lets try this
build price list
--DRIVE TRAIN ONLY---
Engine, pipes, carbs, trans      $7390
chain from redline               $105
used billet kick start lever     $51.50
Phelps Polished clutch cover     $71.00 shipped
Weston ATV case saver banshee    $66.00 shipped
--SUSPENSION--
Fireball Racing LT Banshee a-arms 20% black $673
Fireball Racing LT Banshee 12mm tie rods    $$68 shipped
Elka stage 3's(on sale)                     $1000  (got on sale for $910)
--FRAME--
Keyser greasable steering stem mount        $48.80 shipped.
Powder coating frame and other misc parts   $600
heat sleeve from McMaster-carr              $27.68 shipped
front exaust hanger from Cascade Innov      $42.95
QUad boss chain roller                      $12.02
Mod Quad front chain slider                 $25.85
Turbo Chassis +6 round house w/    carrier  $455
T.M. Design Works Chain Guide               $47.25
40mm ALL aluminum radiator yamaha           $55.75
total so far 10,079
--Electronics--
Kompulsive concepts hardness
$110
--WHEELS/TIRES/BRAKES--
stream line univ brake kit                    $44.86 shipped
9x9 3.0+6.0 rear ITP wheel                    $67.98 ($33.99 x2)
.190 a-6 pro series wheel 10x5 2.0+3.0 front  $123.98 ($61.00 x2)
CST Pulse 22x11x9 6ply rear tire              $305(guessing, lost invoice)
CST Pulse 21x7x10 front 6ply                  $
aptor 700 front brake calipers left and right $60 (used ebay)
JDS Signature Series Rear Banshee Rotor × 1   $65
JDS Twister series front rotor (pair)         $65 (per set)
--NUTS/BOLTS/SEALS--
RMATV= collar $4.81 x2         $9.62      RMATV= Gromet         $6.39
       Joint 1                 $15.27            Washer,plate   $6.42
       Circlip                 $3.23             bolt,flange    $4.38
       o-ring                  $2.30             collar(3.84x2) $7.68
       bearing                 $15.4                      TOTAL $24.87
       gasket(housing cover 2) $4.23
       circlip                 $1.40      RMATV= Spacer,damper $28.36 ($14.18x2)
       washer plate            $4.06                    Collar $5.68
       washer, plate           $2.74                      BOLT $ 9.91
       nut, self locking       $2.62             muffler plugs $5.98 ($2.99 x2)
       washer                  $8.88
       spring                  $4.51     RMATV= ODI grips              $25.99
                         TOTAL $74.26           kick starter rebuild   $13.99
                                                tusk brake pad front L $16.99 (raptor 700)
RMATV= nut                      $7.46           tusk brake pad front R $16.99 (raptor 700)
       tusk flywheel puller     $10.99                           TOTAL $73.96
       spring ($5.68 x3)        $17.04
       hour meter               $29.99
       10x 5/16 fuel/hose clips $9.90
                         TOTAL  $75.38
RMATV= Spacer, damper           $28.36
659 pc Banshee Polished Stainless Steel Bolt Kit   $117.95
JDS custom orders=
--GEAR & MISC--
Thor Enemy Goggle web           $29.95
Cascade Innov Seat cover        $164.95 shipped
TOTAL SO FAR $11,548
--JDS custom orders--
PIVOT WORKS SWING ARM KIT YAMAHA ATV × 1        $42.46
WHEEL BEARING KIT - ONE WHEEL × 2            $23.72
PIVOT WORKS A-ARM KIT YAMAHA ATV × 1            $76.46
LOWER SHOCK BEARING KIT × 1                    $17.81
PIVOT WORKS SHOCK ABSORBER KITYAMAHA ATV × 1        $33.96
PIVOT WORKS LINKAGE BEARING KIT YAMAHA ATV × 1      $67.96
STEERING STEM BEARING KIT × 1                    $8.46
REAR WHEEL BEARING KIT - BOTH WHEELS × 1        20.36
41 tooth Yamaha SPROCKET SIZE / PATTERN:            $40.00
MINI CHAIN PRESS TOOL × 1                        $8.00
clymer                                              $31.41
                                             TOTAL  $$383.81
EXHAUST SPRING × 4                            $56.00
ALL BALLS HEAVY DUTY TIE ROD KIT × 1            $69.00
15t sprocket                                        $19.00
TOTAL on list only is $12,077. Add $2000-$3500 for used banshee. Or add money for used frame/engine core. Engine core is around $1000.
This is cut and pasted from my 521 build. The bike still isnt 100% complete!!! But it's been ride able for almost 2 years.
On 9/12/2017 at 9:03 AM, Richard2112 said:
Also I wanted to get everyones opinion on dmc alien 916s. Really want to get them.
That's a terrible idea. You need to read. They require big bore pipes.
23 hours ago, Richard2112 said:
I'm gonna upgrade the suspension too, in time
 That's easily over 2k.
12 hours ago, Richard2112 said:
Why -2 I was gonna go with +4
Because the shorter the swing arm, the better the bike hooks and turns. I had a +6. I hated it so much, i didnt want to ride my bike. The tires spun until 5th gear. It turned like a boat. I went with a stock length and i'm much happier. And of course due to the traction and power, i cant use all of it's power.
I hope this helps.
  • Like 1
