Weak spark issue
Jeffyjeff
So I put a 421 cub kit on my 96 banshee with 35mm carbs, vforce reeds, t6 exhaust, open air filters, running 160 main jet. Started having a hesitation issue at wide open throttle. Seemed like a fueling issue but went to 170 and then tried 150 neither made much difference. Put a new coil, wires, caps, and plugs and still same issue. After some more testing I found it had good spark at the wire without the caps on it but with the caps on the wire could see no spark touching the plug to the head at .030 gap. So I dropped the gap to .020 and it fixed the running issue. Anyone have an idea on what's going on there? Weak stator, flywheel issue, or coil maybe faulty? I tested the primary side with a test light and it lights up but not very bright is that a sign of weak output from the stator?
