Steering stem bearing nut
On 8/31/2017 at 7:25 PM, bansheekx said:
A 3/4" bolt with a inch and 1/8 head that has 2 nuts locked together on it will work just as well.
Worked perfect. I welded the nut to the bolt. The 1 1/8 head is a little sloppy in there but I was able to use a ratchet so slop wasn't a problem like it may be if an impact was slapping it back and forth.
Thanks again
