Measuring chain wear
How are you measuring? Length? Side play?
As with all the equipment I've ever maintained chain stretch is irrelevant up to the point that it has stretched far enough to alter the pitch to a point that it begins to wear the sprockets.
Just my 2 cents worth.
Is business slow over there.
Measuring chain wear....lol!
I maintain too many quads to just replace chain all willy-nilly.
So far, I'm going with 16 links pin to pin is 10"
Wear limit is said to be 10.98"
That's .06" wear max per pin
The worst "looking" one measures 10.02"
I never said anything about changing chains Willy Nilly. However, if I had your money, I'm sure I could afford to burn mine. Lol!
But seriously, I would just keep an eye on sprocket wear and gauge from that.
That's what I've always done. But since I've found specs I'm curious, as the Banshee Clymer and Regina's website says double the wear limit for non-oring chain.  At .0125" per link, that's 1 1/2" for a +4 swinger chain. I would hope those specs would be for chain failure not just sprocket wear.
1.5" seems excessive to me.
