Bamabansheeboy Posted August 20, 2017 Report Share Posted August 20, 2017 So I'm very frustrated , bought a banshee and it has a cool had , toomey t6 exahaust and sprockets. The power band wouldnt kick in a couple people told me it was thw carbs. I got tired of messing with them so I went with the trinity 2 into since I trail ride mostly. So I got it yesterday and got it on this morning. It fired right up isles nice which it wasnt doing with the dual carbs. Well I get excited jump on take off and when the power band supposed to kick in same thing. Its almost like it hits a rev limiter or something. Any ideas or suggestions? Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 Depending on the year, It could have a park brake rev limiter, although it usually comes on sooner than that. Look for a green/yellow wire at the CDI and cut it and tape it off. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 If it's not that, try trimming back your spark plug wires a little to get fresh contact. Might also ohm test the spark plug caps (boots) Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 Depending on the year, It could have a park brake rev limiter, although it usually comes on sooner than that. Look for a green/yellow wire at the CDI and cut it and tape it off.This green one?Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 If it's not that, try trimming back your spark plug wires a little to get fresh contact. Might also ohm test the spark plug caps (boots)Its actually a brand new coil. Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 Do you have 4 or 5 wires there? Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 Do you have 4 or 5 wires there? 4Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 New OEM (original equipment manufacturer) coil? Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 Do you have 4 or 5 wires there? Any idea what this is for?Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 Just now, Bamabansheeboy said: 4 Sent from my LG-H918 using Tapatalk No, you'd need 5 for it to have it. And it's green with a yellow stripe Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 New OEM (original equipment manufacturer) coil? No its from Amazon. Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 Just now, Bamabansheeboy said: No its from Amazon. Sent from my LG-H918 using Tapatalk Don't rule that out as not being the problem then, might even count on it. Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 Don't rule that out as not being the problem then, might even count on it.Do you happen to know what these may be?Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 20, 2017 Report Share Posted August 20, 2017 Blue goes to the voltage regulator, and black is ground probably for the taillight Quote Link to comment Share on other sites More sharing options...
Bamabansheeboy Posted August 20, 2017 Author Report Share Posted August 20, 2017 Blue goes to the voltage regulator, and black is ground probably for the taillightWanna guess what the problem was?Sent from my LG-H918 using Tapatalk Quote Link to comment Share on other sites More sharing options...
