kawa110 Posted August 12, 2017 Report Posted August 12, 2017 Just trying to find out the easiest way to remove the clutch arm actuator bearing... Maybe someone could hook me up with a link for the proper size pilot bearing remover. I don't want to break these cases. Thanks Quote
sheerider11 Posted August 12, 2017 Report Posted August 12, 2017 Harbor freight blind bearing puller. Has a few sizes. The 2nd smallest one fitsSent from my SAMSUNG-SM-G891A using Tapatalk Quote
kawa110 Posted August 12, 2017 Author Report Posted August 12, 2017 slide hammer, four collets: 3/8 in. to 1/2 in, 9/16 in. to 11/16 in, 5/8 in. to 1 in, 1 in. to 1-1/4 in, convenient carrying case Quote
sheerider11 Posted August 12, 2017 Report Posted August 12, 2017 That's it. Sent from my SAMSUNG-SM-G891A using Tapatalk Quote
Buckeye513 Posted August 17, 2017 Report Posted August 17, 2017 Shop eBay got the same set for $32 shipped. Just FYI Sent from my iPhone using Tapatalk 1 Quote
Ayesully810 Posted December 13, 2017 Report Posted December 13, 2017 Hey how did this work out for u? I need to do the same on my new cases Quote
kawa110 Posted December 13, 2017 Author Report Posted December 13, 2017 Worked great! Used it on 3 other non banshee applications since I purchased it. 1 Quote
Ayesully810 Posted December 13, 2017 Report Posted December 13, 2017 how did u put the new bearing in? Quote
kawa110 Posted December 13, 2017 Author Report Posted December 13, 2017 Lube and gently tapped it down with a socket. Gently I was afraid of breaking the case. Went in easy. 1 Quote
Ayesully810 Posted December 13, 2017 Report Posted December 13, 2017 sweet if u could, Im gunna go to harbor freight Friday and pick that up, can you PM how to use that thing, I forgot my helmet at home today so my brain is not working right Quote
kawa110 Posted December 13, 2017 Author Report Posted December 13, 2017 No problem. Very easy.... Quote
JUSTWANNARACE Posted December 14, 2017 Report Posted December 14, 2017 Heat the cases with a propane torch and the bearing will drop right in Quote
kawa110 Posted December 14, 2017 Author Report Posted December 14, 2017 Obviously beer first.You will see how it actually works when you open the case.Find correct size for hole.Yes remove the washer and seal first.Tighten the expanding attachment to the bearing, ensure your deep enough, but not in the case. Attach the slide hammerSlide the hammer up, and it will “tug” the bearing out. Yes heat the cases and it will fall in. I believe I put the bearing in freezer then lubed and tapped it in. 1 Quote
