Alky pump..
It's not that bad. Take the intake off and the reeds out. Stuff some paper towels in the intake behind the piston. Line the inside of the intake with grease (and edges around paper towel). Put grease on the drill bit before drilling. Put grease on the tap before tapping. Screw in barb fitting for pump. Mark fitting flush to intake wall. Pull fitting out and cut to mark (as not to hang into the intake).Clean all grease out of intake. Pull rag out. Clean well. Put some 1211 on barb fitting and put in and tighten.
So much easier just leaving the reeds in.
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
As explained reeds out with a paper towel is a good start. I usually ask one of my friends to run the vacuum while I drill n tap it takes the risks away big time.
Cool...now if I could just find a barb fitting locally that fits my tube ...
Thanks@justwannarace for the detailed info...and everyone else..
Sent from my LG-D722 using Tapatalk
