Oil leak near front sprocket
Nick.H
  • Replies 46
  • Created
  • Last Reply
Top Posters In This Topic
did you leak down test it after putting all the seals in the motor?   you might have an air leak.
you lost compression on both cylinders or just one?
rather than listen to your mechanic, you should take the advice from here.  its not complicated, and if you spend a few bucks on testers, like the leak down tester, it will save you more money in the long run.
