Rwbanshee Posted July 27, 2017 Report Share Posted July 27, 2017 Replaced seals in the motor. Put new tranny gears and shaft in because the threads for the front sprocket were stripped. And I guess the part I got was bad. I put the chain on and rocked it and it only shifted down once. Pulled clutch cover off and thought it could be the shift arm then I seen that it was stuck in 3rd. The adjustment screw seems fine. Anybody know what's going on? Quote Link to comment Share on other sites More sharing options...
edgehanger Posted August 1, 2017 Report Share Posted August 1, 2017 It's stuck? Start over then and this time make sure the motor shifts through all the gears before you put it all back together. Take it back apart Quote Link to comment Share on other sites More sharing options...
