Drag vs Dune Ported
BBoy69
The porting on a two stroke is like a cam on a 4 stroke. It controls your intake and exhaust durations.
Different port timings will determine when the engine makes peak power.
A dune port will cause the power to come on earlier and more evenly than a drag port that causes the power to come on at a higher rpm range and more aggressively.
On a dune/trail port, the power would come on more evenly as you roll into the throttle and RPMs increase. If you did that on a drag port it would act lazy until it finally reach a high enough rpm range and then it would make power violently.
  • Like 1
